Vivid Racing Tune and Agency Power Exhaust - 600HP
Old Apr 27, 2010 | 03:28 PM
vividracing's Avatar
The guys at Turbokits.com hooked up a 997TT 6spd with a Vivid Racing ECU Flash, Agency Power exhaust, and Agency Power boost recirculation valves to put down 486awhp and 550ft/lbs of torque on a Mustang Dyno. Mustang Dyno's usually read quite low so figuring a 25% drivetrain loss, this is 607HP to the crank!
Old Apr 27, 2010 | 11:12 PM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
Two things bother me about that statement: it's implied that Mustang dyno's aren't really producing accurate numbers (reading low); and that there's a 25% drivetrain loss.
It's always been my understanding that dyno's need calibration just like any other measuring equipment and I wonder why Mustangs "usually read quite low"? And yes, I do understand that you are usually taking relative changes on the same dyno, but still...
25% drivetrain loss seems to me to be very high. It would mean that having awd @ 480hp (crank) would actually result in ~360hp (crank) available to the wheels. A C2S with 385hp (crank) would conceivably now be as fast as a TT...if not faster. Doesn't make sense to me.
Old Apr 28, 2010 | 09:03 AM
Tiago's Avatar
Tiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to behold
Does they have a stock dyno sheet (same day, same dyno) to compare that 486awhp?
Old Apr 28, 2010 | 09:12 AM
I dont know, I was just sharing the video with our products.
What I can say is that the car has 480hp to the crank right? On our Mustang dyno, there is a 20-25% drivetrain loss which would equal about 360-370 to the all wheels. That is consistant with our test on our project 997tt dyno below.
Comparing our dyno results of the JIC Cross exhaust and the Vivid Racing ECU Flash, the results are pretty similar. Our car made 491awhp and 494ft/lbs. See below...
On a side note, someone left me disturbing negative feedback about our Agency Power exhaust... Vivid Racing started testing on this exhaust back in 2007 as you can see the date of these pictures.
Old Apr 28, 2010 | 09:51 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Dan, your dyno results tend to confuse me. A stock tip 996tt makes 355 (thread in the 996 forum), while a stock 997tt makes 360-370?
I agree, this is why dyno's are really tuning tools and should not be looked at for absolute results....
Great gains on the 997tt. Is this the turbokits.com from CT?
Old Apr 28, 2010 | 09:56 AM
Tony I said that in the post above, the stock 997TT makes about 360-370. My personal car dyno above made a little more. A stock 996TT Tip we recently did can be seen here with the baseline - https://www.6speedonline.com/forums/...eady-rock.html
Both numbers match what you said. Now have a great day!
Old Apr 28, 2010 | 04:27 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Well done Dan...Good gains from stock to tuned...we all have to remember that dyno numbers are not for absolute values but for comparison...Abslute number may vary depending upon dyno calibration...but difference from a tune on same dyno,same day,same car and same temp...is actual and real...keep up the good work Dan...
Old Apr 29, 2010 | 07:15 AM
xseal's Avatar
xseal is a name known to allxseal is a name known to allxseal is a name known to allxseal is a name known to allxseal is a name known to allxseal is a name known to all
I agree, the only numbers that matter are difference b/t baseline and results on the SAME dyno. Comparing results from different dynos is of no use, they all read differently. Looks like good results off the baseline.
Old Apr 29, 2010 | 10:20 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
great dan ...
Old Apr 30, 2010 | 06:49 PM
Thanks guys, I usually post as much as I can on owners cars on www.vrtuned.com
Old Apr 30, 2010 | 07:08 PM
AWD Motorsports's Avatar
AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !AWD Motorsports Is a GOD !
Just an observation but maybe I am wrong but 648crank is 486whp @ 25% loss.. You dont add 25% to the wheel # you subtract from the crank # since its a loss..
MIke
Old May 3, 2010 | 09:19 AM
Mike lets not start. You are a vendor and commenting negatively on a vendors thread does not help anyone...
Old May 3, 2010 | 09:21 AM
Was just helping with the Math.. I would APPRECIATE if someone corrected it for me before i made 200 posts like that.. Sorry man.. It wasnt intended to be negative.. If you had posted Seal grey car made 600hp and it was slate grey you would have appreciated the correction No??
Mike
Old May 3, 2010 | 09:24 AM
Lets not ruin another thread. Drivetrain loss is not exact. But the Mustang Dyno reads low...
Old May 3, 2010 | 09:43 AM
The Bogg's Avatar
I'm not a vendor. Mike's math is correct.
Bottom line is that it looks pretty darn good with lots of gain from the software and exhaust.
