Squeaking sound in the back, where is the thread
Old Apr 28, 2010 | 10:56 PM
W1N's Avatar
W1N
W1N is a jewel in the roughW1N is a jewel in the roughW1N is a jewel in the roughW1N is a jewel in the rough
There was a thread a while ago about 07/08 turbos having right rear window or something that is little loose and produces the squeaking sound. I'd like to get rid of that now. Anybody recall the thread or actual info what was it that was loose?
Thanks!
Old Apr 28, 2010 | 11:09 PM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
Old Apr 29, 2010 | 02:39 AM
speed21's Avatar
Thanks!
Yep know it well. Is it a creaking knocking sound? P has had a number of goes at fixing mine now. Last week they removed the rear bar to double check the rear body spot welds as there has been a few cars where one of the spot welds was faulty due to the weld robot out of sync not welding properly and that causes the body to creak. If its that it needs to be re welded to stop it. Alls fine there on mine thankfully. P are now satisfied its definately the rear side window which is moving in the rubber and contacting one of the spot welds when the body flexes slightly over the bumps. The glass apparently then can contact a welded spot on the inside frame @ b pillar base. Before they said there were rivets in there but now say its the spot welding that deforms the frame on each weld so thats what is hitting. They have made a number of adjustments to the glass and rubber now and have got the creak to disappear for a few days but then it comes back. Its actually better now than how it was to begin with but its still not perfectly fixed. It would be great if its not there. some days are worse than others. They say the window has to come out and grind the offending spot back or hit the offending spot to bend it away a bit so it doesnt touch the glass when the body flexes. They say are worried if paint is removed inside in the process then there is a possibilty of corrosion at one stage. Its obviously not an easy job as they are avoiding doing it and are just re adjusting window and rubber instead. Your P dealer would have to know of this common problem.
Old May 2, 2010 | 03:16 AM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
my ashtray does that nois i changed it twice and still it do that noise ..
Old May 2, 2010 | 03:28 AM
2thfixr's Avatar
2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold2thfixr is a splendid one to behold
Ashtray is easy.. just that little plastic part that's used to extinguish cigarettes. Get a glue gun and put a dab in there from underneath to secure it.
Old May 2, 2010 | 09:09 AM
The Bogg's Avatar
I have a small squeaky noise which I finally figured out was the seatbelt "clamp" portion (next to the middle console). Not a big deal but it was a small victory to figure out where the noise was coming from!
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
Perkman87
Nov 19, 2015 05:31 PM
SharkyShark20
Sep 19, 2015 09:54 PM
rnl
Aug 26, 2015 02:36 PM
