Passenger airbag light
Old May 5, 2010 | 09:59 PM
roxorz's Avatar
roxorz is a splendid one to beholdroxorz is a splendid one to beholdroxorz is a splendid one to beholdroxorz is a splendid one to beholdroxorz is a splendid one to beholdroxorz is a splendid one to beholdroxorz is a splendid one to behold
My passenger airbag light comes on and stays on (disabling the airbag) intermittently on my 997tt. Took to dealer, they are not seeing any codes. Problem is it happens infrequently and without fault codes, so very hard to troubleshoot. Anyone else have/had this problem?
Heard it can be linked to battery under volt, but batt was replaced last fall.
Old Aug 30, 2012 | 09:33 PM
MJA's Avatar
MJA
MJA is just really niceMJA is just really niceMJA is just really niceMJA is just really niceMJA is just really nice
Mine just started doing this ? What is the fix ??
Old Aug 31, 2012 | 06:51 AM
jhbrennan's Avatar
A heavy book or briefcase in the passenger seat will cause the light to go on.
Old Aug 31, 2012 | 11:58 AM
kidyeung's Avatar
kidyeung is infamous around these parts
i had the same thing happen. passenger airbag light would go on an off.
figured out the wife left a water bottle behind the seat and put pressure on the seat when i moved the seat back.
also noticed the light would come on if i moved the seat too far back and put pressure on the seatback.
Old Aug 31, 2012 | 01:21 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
IIRC there are 4 sensors on the seat frame that will sense weight in the seat and if something under 40 or 60 lbs is placed/sitting in the seat the air bag will NOT go off in an accident. So, the light should be on with something under that weight in the seat but should the light be on with nothing in the seat?
Old Aug 31, 2012 | 03:37 PM
jhbrennan's Avatar
The warning light is labeled "passenger airbag off". When you first start the car, the light illuminates as part of the test feature of all the warning lights. If it stays lit with no weight in the seat or with an adult seated in the seat, then there is a problem.
GSR Autosport
Aug 26, 2015 05:20 PM
pwdrhound
Aug 23, 2015 07:36 PM
riozilla
Aug 21, 2015 11:34 PM
Walorus
Aug 18, 2015 01:39 PM
