Oil change DIYer help please !
Old Jun 20, 2010 | 11:34 PM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
Hello Guys,
I did an oil change on my 07 Turbo today following bbywu's DIY ( Thanks alot man!! ) . Oil tank and crank case was pretty easy. But When I removed the torx bolts under the turbo reservoirs right below the oil line?, there was no oil coming out. Not even a sign of oil in the bolt hole. Did I drain the right bolts? There were no other bolts that i could find on the reservoir.
Also the shop I got the filter and washers from didn't include the smaller o-ring for the filter and I couldn't see it on the oil filter either, so I just replaced the bigger o-ring and put the filter back. Should i go get the o-ring and reinstall the filter?
They also gave me the wrong crush washer for the crankcase bolt , and I had to reuse the old one. I should probably get a new washer and redo the crankcase bolt.
Any thoughts?
Thanks alot for the help!
Old Jun 21, 2010 | 04:48 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
Don't worry too much about washer and o ring, sometimes it's better to use the older ones, if the washer is doing it's job once you installed it don't change it. As for the draining question, this is odd. There are two drain plugs, one is on the right side in front of the right side header, the other Is dead center of the engine directly between the headers, hope that helped
Old Jun 21, 2010 | 06:48 AM
dinorocz's Avatar
these two red circles are where you need to drain the oil, this was a picture I took of a set of new headers I was installing on a friends car
Old Jun 21, 2010 | 08:04 AM
Abby997TT's Avatar
Thanks for the help Dinorocz!
I got the drains on the oil tank and crankcase right, but when I did drained the turbos, nothing came out ( 1 torx bolt on each turbo oil reservoir).
Old Jun 21, 2010 | 09:13 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
Always change the o-rings and filter rings when you change the oil. Also, only use dealer purchased stuff.
Old Jun 21, 2010 | 09:16 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
As to my knowledge,996TT had drainplugs for the turbos...997TT does not have...
Old Jun 21, 2010 | 10:17 AM
dinorocz's Avatar
Only need to drain the two I circled thats it
Old Jun 21, 2010 | 10:41 AM
Sorry,but have you changed only one header?
Old Jun 21, 2010 | 10:54 AM
Page's Avatar
Page is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of lightPage is a glorious beacon of light
Here in the states we have a lot of tracks with left turns. So I guess he needed more power on the driver's side (left side) haha..
I'm sure the picture was taken during the process to compare.
Old Jun 21, 2010 | 04:14 PM
Abby997TT's Avatar
Thanks! Then I did the right drains
Old Jun 21, 2010 | 04:16 PM
Abby997TT's Avatar
Thanks alot! I guess that's why there's no oil coming out.
Can anyone with a shop manual to confirm there are no drains for the turbos please?
Old Jun 21, 2010 | 09:31 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
Correct, there are no turbo drains on the 997TT. The 996T had drains, but Porsche must have figured out it was not necessary and removed them on the 997
Old Jun 21, 2010 | 10:33 PM
speed21's Avatar
Youre right!! Verrry odd. I header only.
Hey skand I thought you may have linked him up to that near disaster of yours with the small filter o ring??
As a DIY job it'd definately pay to change it out just to be on the safe side.
Old Jun 21, 2010 | 11:32 PM
Abby997TT's Avatar
Thanks alot PorscheDoc! What's your take on the small o-ring for the filter? Should i get new o-rings and redo the filter?
Old Jun 21, 2010 | 11:34 PM
Abby997TT's Avatar
Thanks Speed21! I will probably redo it since it only takes a few minutes anyways.
