Official APR Tuned 997TT FAQ Thread......
The 764 plate copes very well on 93 and 100 octane. However, I only have a 1,000 miles on the clutch after the 500 mile break-in. No issues and yes I am running APR with FVD Gen 2 exhaust. I do not plan on upgrading my turbos, I see no need to for a DD and the occasional DE.
Would also like for matthew to respond to his thoughts regarding my earlier post.
At 1k there are no issues. SACHS was recommended by APR for the 997tt. Engagement and response does "feel" different-improved and quicker. But not on and off like a racing clutch. Very much like stock, perfect for a DD with the occasional DE. I will keep you posted when I run 100 octane.
Sorry again lol, it was a long day yesterday. Stock intercoolers, and we upgraded just the disc and plate with stock flywheel.
Let me know if you have anymore questions, I'm here all day
Matthew i note on Sachs website, see link http://www.sachsperformance.com/sach...203/index.html where they list 2 performance pressure plates.
One is rated at 740nms and the other is 890nms. If APR quote 865nms torque then the 764 pp is running rather close to its limmit isnt it??
Obviously the 752 plate wouldnt hold that 865nms. The 752 plate is obviously what you guys quote as a stage 2, so thats definately out as a viable clutch mod. And the 764 being the stage 3. Some performance shops your way market that as a 2.5 i believe? Your thoughts?
Is there any Sachs pp that is really going to hold that 865 torque for very long. I also note the clutch disc is the same in both applications (excepting the ceramic segmented disc but that'd be not so nice to use other than race).
Re the tiptronic gearbox, how is that possibly going to cope given it is totally stock? So what are owners in for????
What is the expected durability of these tip gearboxes and manual clutches running the APR tune?
I would assume that the 740nm 752 pplate is what Porsche use as their stock plate given that the engine in stock tune trim produces 680nms breifly in Sports C mode at WOT. So If P has a allowed safety factor of 60nms up its sleeve to accomodate for the 680 nms how does the 764 cope with 865nms if there is only a safety factor of 25nms?
Just curious..
Just curious..
Speed21,
Where are you getting your information from regarding what clutches we use?
With that said we do use a clutch that is rated at about 650 ft lbs. Sach's clutches are a bit underrated and have no problem handling the extra 30-40 ft lbs that APR claims. It's their stongest organic clutch disc and plate set up if I'm not mistaken and it's working great. Our local client has taken it to several track days over the last year, and drives it hard just about every weekend out on his back roads near his home just outside charlotte and it still holds strong.
Seeing the timeslips esp for the tiptronic car, these are for sure hell of fast times for just a flash and 100 octane gas
But then again these are some pretty smoking 60ft times
I always wondered how on earth one achieves these times (1.5 secs) esp on stock tyres...
These proves how different the tip to manual cars are and the super advantage the launch control and esp the "building up boost from standstill" fucntion that comes with launch control, gives to the tip cars...
In my opionion a 6speed car with the exact same setup would never see these times...
Nevretheless these are upgraded vtg's (good ones) and IC's 1/4 mile times and I am most certainly impressed!
Btw Matthew to make sure this isn't completely outside of this thread, I just wanted to double check that this is for a 997.2 turbo? Is there going to be difference between a PDK tune and a 6speed tune? If this is just for a 997.1 turbo, let me know if APR wants a test client for a 997.2 turbo that can do all logging, dynos, etc necessary. Renntech people have also pushed me towards APR as a great tuner.
Honestly I'm inclined to just do a APR tune. I can't believe how much people are *****ing about a couple hundred bucks difference. Tunes for Porsche's seem damn cheap compared to ones for Mercs.
GTsilver2010
APR doesn't have software yet for the 997.2TT. These software numbers are based off the 997TT first gen.
APR does all their testing and tuning in house so it would require your car be sent to APR for proper testing. This can take as long as a few weeks or a few months. I do have speedART software available which we import from Germany if your interested shoot me an email @ mkrisel@gmpperformance.com.
turbo times
100octane/clutch
Getz,
I can't say for sure how long the tranny will last. I can only give you information based on previous experience with my local cars.
The tip car we had here was drag raced often. I would say at the very minimum once a month and always ran 100 octane just like the manual one also posted in this thread. He has had the software in his car since fall of 2007.
The tranny has yet to slip or so any signs of failure. I think if it couldn't handle the power I think it would have showed some signs already with over 2 years of abuse.
However if you do run into issues with it we can flash the car back to stock completely and wipe out every last trace of APR software by sending you our laptop and have it covered under warranty.
Simply just re download the stock file. You can send us your ECU too as well but that's more work than necessary.
Hope this info was helpful.
I have heard that the Merc biturbo V12 cars use the same tranny and have mid 600s for torque so it may be okay for the long haul. I may have to give this some more thought. I just spend an extra 2 grand for a CPO, and I would hate to lose that..
-Getz
-Getz
. Im assuming the clutch is a bit more grabby when it does begin to take up? Just like to know all the differences a user should expect when doing an upgrade of this nature. Thanks
.Speed21,
Getz,
This would have to be food for thought for any tiptronic gearbox P car owner. Many here are focused on the speed and performance aspects of the APR tune which is fine however as you know from my previous posts i've always had a keen interest in establishing the knock on effects of a tune upgrade.
Sometimes all that glitters is not gold.
Purchasers should always be made conscious of the risks.
PS. On the warranty aspect with Porsche, I thought the jury was still out (re the recent Softronic Tune critisism's thread) whether any tuner was able to keep a tune totally undetected from P's prying eyes in the event such catastrophe occured and a bogus claim was later found made.
Needless to say there is also a very serious honesty issue at stake here as well.
I run APR software for about 13000miles without any tip slipping issue...and of course,car runs flawless every day...Couldnt be more happy...However I am thinking of installing a set of IC in order to lower IAT during the hot Greek summer...
