door panal removal
Old Aug 22, 2010 | 08:02 AM
tclayj's Avatar
tclayj is infamous around these parts
door panal removal
I have noticed a rattling noise from the drivers door panal speaker area when listening to music. I am assuming that a fastener has come loose from the speaker or a panal fastener is loose. It does not sound like a bad speaker. Is the door panal easy to remove ? Are special tools needed ? Where can I find instructions on removal ? Any help would be appreciated.
Old Aug 22, 2010 | 02:08 PM
bbywu's Avatar
Old Aug 22, 2010 | 06:32 PM
NeilM's Avatar
NeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond reputeNeilM has a reputation beyond repute
be careful in doing this. I did mine myself several months back to install some carbon bits. make sure you use a plastic pry tool and line the edge of the door panel with masking tape(on the metal part of the door). There's also a pattern you need to follow when removing the actual panel from the door. Take your time and good luck.
NIKAS
Aug 20, 2019 07:53 PM
markj
911
Apr 7, 2016 05:44 PM
simoncpw
Sep 8, 2015 10:55 PM
AM v12v
Sep 4, 2015 02:52 AM
