IPD Plenum install
Old Sep 14, 2010 | 02:18 AM
trompazo's Avatar
trompazo is infamous around these parts
IPD Plenum install
I am in the middle of installing my IPD Plenum and Carbon Y-pipe.
When removing the stock plenum, there are 4 vacuum lines. One is large andn has a one-way check valve. The other 3 all have similar sized ports. When I removed the middle one, it steps down to a tiny hard vaccum line. After I disconnected this hose, I grabbed it and the tiny hard end was loose and did not appear to be attached to anything.
Is there a breather on the plenum that goes to atmosphere? If so, even though its a small line, wouldn't this cause a boost leak?
Old Sep 14, 2010 | 07:18 AM
yllwturbo's Avatar
yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !
if this is the case u had prior vac leak. the small hose probably goes to your FPR which is on the right side. back track it . good luck
there is no breather coming from the ipd
Old Sep 14, 2010 | 10:52 AM
trompazo's Avatar
Thanks, it probably broke when I was removing the stock plenum.
It's hard to get at the lines on the back without pulling and putting some tension on the lines. The one that appears to go to nowhere is a tiny hard/brittle hose, so I suspect it's easy to break if pulled on.
PenguiN
Oct 26, 2018 07:23 AM
PenguiN
Sep 15, 2015 11:44 AM
km90265
Aug 31, 2015 11:00 AM
magoochi
Aug 23, 2015 05:54 PM
ppwchiang
Aug 20, 2015 10:28 AM
