Pics of mod work on my 997.1
Old Sep 17, 2010 | 07:41 PM
jhbrennan's Avatar
Originally Posted by fastlaw
Some pics of work that's being done. Im getting protomove VTGs, Champion IC, new clutch, proto x-pipe exhaust, new plugs, new injectors, BMC filter, and 2 protomotive tunes to accomodate running E85 or 93 pump.
Nice stuff - you're not realty going to run E85 are you? I thought there was a lot to do to upgrade the "internals" before running this.
Old Sep 17, 2010 | 07:44 PM
fastlaw's Avatar
fastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud offastlaw has much to be proud of
Originally Posted by TTdude
Very cool. Congrats. What's the difference between the recent vtg upgrade vs standard? It would interesting to see some performance numbers with your new vgts. Does anyone know what the drone is like on the x-pipe exhaust?
Proto has three exhaust options with varying degree of sound/drone. the 2.5" has little to no drone at highway speeds, its the most popular from what i understand. the 2.75" has some drone, as well as much louder sound when getting on it (this is the one im getting), and there is a 3" wich apparently has more drone and really puts out lots of sound. I chose the 2.75" because i figured it was the best compromise between drone and restrictiveness. oh yeah, mine is cat less also.
Old Sep 17, 2010 | 07:48 PM
fastlaw's Avatar
yes, i am going to run E85. there's a huge performace boost. actually, other than tune, there are minimal changes that have to me made, the biggest of which are larger injectors which run less than $300.
Old Sep 17, 2010 | 11:54 PM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Originally Posted by Abby997TT
It's probably " extrude honed hot housings for vgts" Todd said they will make our vtgs make power like GT2 turbos.
they produce a lot more power than modded GT2 turbos
Old Sep 18, 2010 | 04:29 AM
jhbrennan's Avatar
I realize E85 has a much higher octane rating but this is what I would be concerned about -
E-85 ethanol is used in engines modified to accept higher concentrations of ethanol. Such flexible-fuel vehicles (FFV) are designed to run on any mixture of gasoline or ethanol with up to 85% ethanol by volume. There are a few major differences between FFVs and non-FFVs. One is the elimination of bare magnesium, aluminum, and rubber parts in the fuel system. Another is that fuel pumps must be capable of operating with electrically conductive ethanol instead of non-conducting dielectric gasoline fuel. Fuel injection control systems have a wider range of pulse widths to inject approximately 40% more fuel. Stainless steel fuel lines, sometimes lined with plastic, and stainless steel fuel tanks in place of terne fuel tanks are used. In some cases, FFVs use acid-neutralizing motor oil. For vehicles with fuel-tank mounted fuel pumps, additional differences to prevent arcing, as well as flame arrestors positioned in the tank's fill pipe, are also sometimes used.
Old Sep 18, 2010 | 09:07 AM
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
I believe most of your points are covered by OEM manufacture since MBTE was
banned(2003) and all gasoline sold it the US was switched over to E10.
997TT comes with 60lbs injectors as standard and twin fuel pumps.
The 997TT OEM fueling system has enough overhead to accommodate E85 which requires 30% more fuel/flow at stock HP/TQ levels.
With upgraded 80lbs injectors you can mod the car to 700HP/TQ level, this is what I am running with no ill effects.
Old Sep 18, 2010 | 09:29 AM
Rascus's Avatar
Rascus is infamous around these parts
So you can run E85 in it with no ill effects off of the baseline engine or do you need to upgrade the injectors?
My buddy runs it in his STI out here a lot.
Old Sep 18, 2010 | 09:34 AM
fastlaw's Avatar
you need to upgrade the injectors to at least 80lbs. as to the car suffering no ill effects, i havent heard of any thus far. Venkat seems to have no complaints. I realize that this is a newer mod and certainly want to know if anyone has any authoritative info on running E85, either good or bad.
Old Sep 18, 2010 | 09:39 AM
You will need a E85 tune for sure and based on your power level option are
stock injectors
stock injectors with 5Bar FPR
80lbs injectors.
Old Sep 21, 2010 | 11:46 AM
fastlaw's Avatar
More Pics
Here's the x-pipe exhaust clutch and injectors.
Old Sep 22, 2010 | 07:53 PM
fastlaw's Avatar
proto turbos!
fastlaw's Avatar
Old Sep 24, 2010 | 01:50 PM
fastlaw
is the installation complete?
What are the 2 pictures of MAF for on your picture share?
Old Sep 24, 2010 | 03:13 PM
fastlaw's Avatar
^^ no, the car isnt ready yet. I didnt take the photos of the MAFs; im not sure why they took those pics. i will ask.
by the way, i am having all of the E85 harware componants installed, but i am going to do a MS109/93 tune for now. I havent had my car for so long that i plan to use it as a DD when i get it back and i dont want to have to drive 1/2 hour to the nearest E85 station. However, i understand that Valero is planning to build more E85 stations in the area, so hopefully one is built closer to my house.
Old Sep 24, 2010 | 03:42 PM
ModBargains II's Avatar
ModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to beholdModBargains II is a splendid one to behold
Wow! Insane build!
