TPMS acting strange
Old Jul 3, 2011 | 07:10 AM
lardog's Avatar
lardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to alllardog is a name known to all
Originally Posted by handdoc
sounds like dealer time...certainly a warranty issue if they are the original sensors...if not they may give you a hard time
warranty what? I run 33 37 hot. when cold they trip a code. reset when you start the day and its all good.
Old Jul 3, 2011 | 08:05 AM
SonicKrack's Avatar
SonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of lightSonicKrack is a glorious beacon of light
Reset will work for me until the engine is stopped/restarted. I have to check and see if the partial load is selected, as I drive it usually alone or with my wife's hot sister... naaa, just kidding
Old Jul 4, 2011 | 06:50 AM
Jersey Shore's Avatar
Jersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to beholdJersey Shore is a splendid one to behold
Check to make sure the gauge you are using is correct and not the tpms. Second I had problems on my 08 with no reading, low pressure, etc. They dealer said their is a "module" that reads the info from the tire pressure monitors and that they go bad sometimes. Might want to check that. I put new wheels and tires on the car right after and no problems since.
JS
Old Jul 13, 2011 | 11:20 PM
dan1423's Avatar
dan1423 is infamous around these partsdan1423 is infamous around these parts
I am having the same problem...out of the blue on June 30 my left rear showed -4...i keep a manual gauge in the car, all 4 tires were fine...for the next few days i would have to reset it every time the car was started...i didnt have a problem for 2 weeks and tonight, same problem...i put new tires on in may but didnt have a problem for a month so i dont think its that but i did wash the car last night, maybe it is a moisture problem?
Old Aug 7, 2011 | 01:45 PM
sbkim's Avatar
sbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond repute
Bump - having the same issue after driving in the rain. It happens to be the front right (passenger) side. Anyone found a fix for this? Tried resetting but to no avail
C5tt
Oct 24, 2015 07:35 PM
agentsmurf
Cayenne 955/957
Oct 17, 2015 02:10 AM
Mz3bo
Oct 1, 2015 06:32 PM
nagual911
Oct 1, 2015 01:52 AM
PelicanParts.com
Sep 25, 2015 03:17 PM
