Brake Line Question
Old Nov 18, 2010 | 01:47 PM
vividracing's Avatar
unless the line was damaged, cut, bent/kinked, or you used some type of wrong fluid that would clog them, I see no reason to.
Old Nov 18, 2010 | 02:14 PM
Member1's Avatar
Member1 is infamous around these parts
Originally Posted by TT Gasman
Ok Dan how do you know when the inner linings, either rubber or teflon, are going bad? The OEM Porsche part has a stated 6 year duty life at which point they must be replaced. For the record, exactly when do the ss lines need to be changed? As I said ss lines are great on a race car with regular teardowns and replacement. Thanks
http://forums.pelicanparts.com/porsc...ines-last.html
OK, so your argument is based on a five year old thread that reffers to an event that happened two years prior (7+ years total)? I'd venture to guess the SS brake line manufactures have made some improvements over the years.
As Dan stated, not trying to start a fight, but this information is not correct. Stainless Steel brake lines are safe, so long as they are installed properly, just like most other modifications.
SS lines very rarely just GO for no reason and if inspected (yes, they can be inspected just like rubber lines) there should be no issues.
Mike
P.S,
I agree with you on Roll Bars in a street car. Unless of course you wear your helmet at all times, which can be kinda fun . . . .
Mike
Old Nov 18, 2010 | 02:20 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
That's just an example. I'll stick with OEM brake lines. Do as you wish.
Old Nov 18, 2010 | 03:07 PM
WhiteKnight's Avatar
WhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to beholdWhiteKnight is a splendid one to behold
Originally Posted by bonehead
I had them installed on the TT.
Benefits (from googling:
- Less Expansion
- No Heat Fade
- Reduce Pedal Travel
- Shorter Shopping Distance
- Increased Brake Efficiency
- Abrasion / Corrosion Resistant
Downsides are reports of the lines bursting and/or failing at the fittings. They should be DOT or TUV approved and fully stainless.
For a DD, I'd probably stick with OEM lines. But with as little as I'm driving this car and with the power it should be putting down, I wanted more stopping power with full realization that I would need to eventually change them out as I would a set of tires.
don't install it because 997 tt has ''pre-fill system'' which needs expansion.
Old Nov 18, 2010 | 03:13 PM
Gary II's Avatar
Gary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of lightGary II is a glorious beacon of light
To elaborate on that example...
That's what I would call "back yard brakes", and the choice components and assembly of that system is very telling. Who knows how those lines were speced out, or if they were even being used in the application in which they were intended for.
Using a custom line like that for a "home brewed" brake system with OEM Porsche calipers, gawd knows who's discs and hats, is quite a bit different than using a Goodridge® brake line that was engineered, manufactured, and quality controlled for a specific application.
I know we are still talking about your own opinion, but sharing such a strong opinion based on bad information deserves to have a rebutal that can hopefully give people a better chance to make an even more eduated opinion. (not saying you're opinion is not educated, but it's obviously based on different experiences, and a different school of thought)
Cheers
Old Nov 19, 2010 | 12:39 PM
vpmick's Avatar
vpmick is infamous around these partsvpmick is infamous around these parts
hey Dan with Vivid...PM sent
Old Nov 19, 2010 | 12:47 PM
Replied. Thanks
Old Nov 19, 2010 | 02:15 PM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Originally Posted by vpmick
Does anyone know if a stock 2007 997 TT have steel brake lines? My car is in the shop for winter maintenance so I can't go check and I'm curious. I noticed Vivid sell a braided steel brake line upgrade so I'm assuming oem is not?
Techart offers a brake line upgrade which should be TUV approved
Old Jul 19, 2012 | 12:20 PM
The Bogg's Avatar
Just came across this thread as I was planning on commenting on the ss brake line "upgrade" that I did recently.
I bought the parts thru Suncoast and they are labelled as RSS parts. I was quite pleased with the change in pedal feel with these, although I realize that part of it may be due to the Motul higher grade brake fluid.
I'm not a track hound but I do go at least once a year. The stock brakes worked great at Mosport even with a fairly vigorous driving pattern. I doubt I would ever overwhelm the stock setup but I'd have to say that the improved pedal feel with the SS lines is worthwhile imho.
COBB Tuning
Jan 1, 2025 09:02 AM
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
