first start up in spring
Old Jan 29, 2011 | 11:39 PM
  #31
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Originally Posted by dwags
it's the oil that needs to get above 212 to burn off moisture. oil is hottest in the main bearings where it is under the most load.
the coolant temp sensor is where? has it cooled below 212 before it gets to the oil cooler? i don't know. if the coolant is less than 212 in the oil cooler then you better make sure the oil temp sensor is over 212.
the cats are not going to be happy burning when they work the hardest(cold startup) without cooling air from a moving car.
ever see a car that spits out water as it accelerates onto the highway? that's condensation that has built up in a cold exhaust on a cold day. how sure are you that the entire exhaust system is over 212?
if your not going to drive it, leave it alone. just leave the car in 4th gear and give the car a bump every week to keep the rings from sticking.
Sorry but not buying your reasoning. First, oil temp rises fairly rapidly upon just idling, high enough to burn of any condensation which I would imagine is a miniscule amount not worth worrying about anyway, imo. Second, cats need to reach temp before they become active. Below the activating temperature they just don't work very efficiently. Third, water is a product of combustion, so what you are seeing on a cold day, or first thing in the morning, is not condensation that has "built up" over night but rather H2O gas from the combustion condensing on a cold muffler/tailpipe. When the muffler/tailpipe heats up, it doesn't condense.
Old Jan 30, 2011 | 06:36 AM
  #32
sbkim's Avatar
sbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond repute
Quick ? - is 50 psi tire pressure really needed for 2 months of not driving? I currently have them to factory spec but wasn't sure about needing to put more in.
Old Jan 30, 2011 | 07:12 AM
  #33
dwags's Avatar
dwags is just really nicedwags is just really nicedwags is just really nicedwags is just really nice
i have seen air cooled race cars tape over their oil coolers on cold days because they are not getting enough temp on the track. they need to idle for a couple minutes to get any temp so. even a minuscule amount of condensation will add up over repeated cold starts. some cars that are not driven hard or only for short trips actually have water pour out for a fraction of a second before oil during an oil change. i agree cats need to get hot to become active, however the rich fuel mixture needed to start a cold engine gives the cat a lot of work to do. without airflow the cat gets real hot after start up to burn off the excess fuel. some owners manuals i have had say to start the car and drive off, do not allow to idle for prolonged periods. i know that h20 is a product of combustion. and it collects in the muffler. how certain are you that its all gone after a 5 minute idle? that's why you need to drive the car and everything rocket hot to burn it all off. i just don't think letting it idle or bliping the throttle accomplishes that.
Old Jan 30, 2011 | 08:54 AM
  #34
quattrogeek's Avatar
quattrogeek is infamous around these parts
Originally Posted by Abby997TT
We should do a cruise soon when the sun comes out.
Anytime you wanna go, just message me. I got my plugs, coilpacks, maf all sorted out so she's running much much stronger now..i might be able to stay a little closer this time..
911TurboRules
Jun 23, 2024 06:59 AM
vr6tee
Sep 16, 2016 10:41 AM
MadWhip
Sep 3, 2015 02:04 PM
ECS Tuning - VW
Aug 26, 2015 12:33 PM
ECS Tuning - VW
Aug 25, 2015 11:53 AM
