Need feedback on DME readout from 997 turbo
Hi guys.
Need some feedback on DME overrev from 997tt I am purchasing. It is a CPO.
range 1 - 759 747.1h
range 2 - 120 739.3h
range 3 - 26 739.3h
range 4 - 4 739.3h
no range 5 or 6
Should I be concerned about range 4?
range 3 - 26 739.3h
range 4 - 4 739.3h
no range 5 or 6
Guys,if you plug piwis to read your revs and at the same time drive your car to rev limit,you will see that tachometer shows less rpm than actual...when you hit limit at e.g. 7000rpm the engine really revs at 7200-7300rpm...
The above car had a misshift for sure (hours of over revs are the same for range2,3,4) but i wouldnt worry about it...
Do you know if the Durametric data log shows the number of programming?
There's lots of info in the report but this seems to be the only line item that might contain the programming??
Type ID DME control unit _997TUS00
Does that look like it?
I've asked this question of Durametric and never received a response. I regularly check my readings and at 631 hours (I'm over 650 now) my ranges 1 through 5 all incremented by 1 ignition. I don't understand this at all especially since I never get close to the rev limiter and am not aware that I ever have gone over 6,000 rpms...and 1 ignition in all 5 ranges?? Since there are 3 ignitions for every revolution, how do you get 1 ignition all the way from range 1 through range 5? Manual transmission, ECU not modded. Any thoughts.
I have looked at several DME reports while shopping for 997tt and most of them showed number of programming as 02. Couldn't imagine all those cars had been flashed and plus some of these were certified as well. I was thinking maybe it was due to software update by dealers during service/scheduled maintenance.
By the way, going back to my original question, i assumes these numbers are not too bad and they are not a deal breaker, right?
