997.1 engine air filter change?
It doesn't clog as dirty LMFAO because all of the fine dirt particles pass right through the filter and instead of dirtying the disposable throw away paper filter rather the dirt piles up as black dirty soot into the plumbing and intake manifold.
why you think an oil lubricant is required to help trap the dirt that is an extra cost and an extra maintenance step that the cheaper paper filter does simply as it is supposed to..like ummmm filtrate air pollution?
here's the real deal...you want to squeeze (I give you extra 2HP at best) on a track day at the Porsche Cup race if you feel every little bit of HP helps on your ECM and Exhaust tune will give you...sure drop in an oiled K&N or BMC filter for the few hours on the track.....
That filter and a good down wind ..may be.
I run a BMC filter and honestly I think it slightly altered the pitch of my engine note. The key to using oiled filters is not over-oiling or running it dry. ITG makes some foam element filters (dry) but not sure if there is a factory fit for our cars yet
It does alter the sound definitely. You hear a greater audible wooooshhhh...
Still aint worth the dirt... Listen I'm talking about MY OWN EXPERIENCES.
I don't voice an opinion unless I've been there done that.
Just giving opinions as I see it...the good the bad and the fugly..take it or leave it.
LOL, I run the BMC too. But I think replacing an old dirty filter with stock, gives that better feel also. For the price and being reusable its a great option.
None
what about K&N? BMC is $225 when K&N is less than half that.
This has been covered many times throughout many forums...
Bottom line is the best solution is the OEM intake and filter. You get nothing (other than sound) from the oiled filters...Why? Because they let more air/dirt through....Oil them up and you can buy two new MAF sensors...Not worth the risk if you ask me.
Other intake styles - Laughingly called Cold Air Intakes, actually let more hot air in to the system and actually reduce power...But again...They do sound different...
So, if you want to sacrifice HP for sound....get the aftermarket intake....If you want to risk destroying the MAF's then...drop in filters.
If you want the best solution...keep a fresh, clean OEM filter installed...
Good luck!
DC
Good luck!
DC
No one could figure out where the cold air was coming from and there was so much laughter that the vendors had to change the name to "Competition Air Intake".
I mean they look cool and sound cool, so we almost try to convince ourselves that they will improve performance. Maybe that is the Cool they are referring to..."Cool" looking - "Cool" sounding....hahaDC
Wrong air filter?
Hello... newbie here. I just bought a 2007 997 TT and was looking into the air filters to replace the one I have. Every time I search for the air filter that should match the car, the results come back to the irregular shaped filter as opposed to the rectangular shaped filter (see both pics). I know the rectangular shaped one is the correct one, but what is the other one for? does that go somewhere in the TT too? If yes, I will keep it, but if no I will return it.
Plus, does K&N make the rectangular one? I cannot find it... I am only finding it at BMC.
Please advise.
Thanks.
Please advise.
Thanks.
Please advise.
Thanks.
Please advise.
Thanks.
