Washing your car and getting the engine, airbox and blower wet
Old Mar 5, 2013 | 02:16 PM
  #31
bbywu's Avatar
I think they are referring to Cosmoline. It's that dull brown/yellow coloring you find on the crankcase. It isn't found on every component in the engine bay.
Old Aug 21, 2018 | 08:52 PM
  #32
henryting's Avatar
henryting is infamous around these parts
I know what you mean, I get paranoid too whenever I wash my 997.2 with the entire engine wet comes sloshy wet. I solved the problem by cutting a sheet of plastic canopy that I tuck on top of the engine bay and then close the lid This way regardless of how much water I sprayed through the air vents, it will stream away to the side of the engine bat and channel it out. I was extremely happy in avoiding all the vital sensitive parts getting wet. After I'm done wash and drying the car, I just pop open the lid and remove the plastic sheet, leaving the entire air box, filter, alternator, belts, pulleys etc... all bone dry.
Old Aug 21, 2018 | 09:52 PM
  #33
ThunderRolls's Avatar
ThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to all
Originally Posted by speed21
Im with you Doc. Putting mats and things to cover up on the outside is a little pedantic. Some of you guys need to stop worrying so much about a little bit of water and spend more time driving the pants of the thing.
this
Also, the cel is more likely to have come from your battery compartment getting wet.
Old Aug 22, 2018 | 10:12 AM
  #34
997TTEQNY's Avatar
997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future
Mine always squeals after a wash.
one blip of the gas, and it goes away
Old Aug 23, 2018 | 10:49 AM
  #35
Dguth's Avatar
5 Year Member
Dguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of lightDguth is a glorious beacon of light
Same here. I usually power wash mine in a bay. I usually go pretty easy on the rear slats area. But every time I do the initial crank after a wash, you here the creaking/groaning from the belts and then it goes away after 2 seconds.
Old Aug 26, 2018 | 11:52 AM
  #36
hollywood996tts's Avatar
hollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura abouthollywood996tts has a spectacular aura about
Mine squeals too but only noticed after I stopped hand washing it myself and had a co come to my home to wash with a sprayer. When I used to hand wash it was with some blue solution I think it was made by that Opti co. maybe it's called opti clean and it gets heavily diluted with water. One gallon and one tentacle micro fiber sponge and one panel at a time from top down. I'd dry each panel with a micro fiber cloth right after I wiped it down. Worked well and hence the water in the eng or other cracks was always minimal. Maybe I will start doing that again. It's a small car hence doesn't take too much time.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
vr6tee
Aug 29, 2015 03:52 AM
ritchrwi
Aug 20, 2015 05:19 PM
Gewgaw
Aug 19, 2015 11:52 PM
