Compression Testing
Old May 31, 2011 | 10:56 AM
arash's Avatar
arash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to behold
Compression Testing
I've seen a lot of folks advise doing a compression test during a pre-purchase inspection. I'm wondering:
1) How necessary is this on a <10k mile 997 Turbo?
2) How much do these generally run in terms of hours of labor? I'm getting wildly varying numbers.
Thanks,
--arash
Old May 31, 2011 | 11:02 AM
bonehead's Avatar
bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !bonehead Is a GOD !
I have never heard this done on a low mileage TT. Don't see any reason for it unless you suspect it was driven into the ground (in which case, you should walk away anyway) or it was heavily modded from day one. Routine PPI/DME scan should suffice.
Old May 31, 2011 | 01:36 PM
arash's Avatar
What sort of labor is involved? It seems like it's quite an operation.
Old May 31, 2011 | 01:46 PM
ntlgnt1's Avatar
ntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud ofntlgnt1 has much to be proud of
They would have to access the spark plugs to do the test, most likely require an engine drop otherwise pretty straight forward. I wouldn't think this is necessary if the DME checks out fine but it does add another layer of thoroughness.
Old May 31, 2011 | 02:18 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
it would be the same labor cost as changing the plugs - $600-1000 approx
Old May 31, 2011 | 10:32 PM
TT Surgeon's Avatar
I wouldn't bother on a low mile unmolested car.
Old Jun 1, 2011 | 01:20 AM
speed21's Avatar
Must be a lot of gullible "folks" around. What?....on a 997tt? This is complete utter nonsense.. Name names.....just one will do.
rzmnco
Cayenne 955/957
Oct 7, 2025 03:12 PM
dc2000
Sep 16, 2015 11:53 PM
longboarder
Sep 12, 2015 12:55 AM
