VTG 68 mm vs. GT28
Old Jul 21, 2011 | 03:28 PM
TwinTurboM3's Avatar
TwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud ofTwinTurboM3 has much to be proud of
VTG 68 mm vs. GT28
Any tests of GT28 vs. VTG 68 mm?
How is the spool?
Rather than putting a set of 68 mm VTGs how would twin GT28s work?
Old Jul 21, 2011 | 04:33 PM
Trevor's Avatar
Trevor is infamous around these parts
Here's a graph comparing a VTG setup with intake, exhaust and a tune against Switzer's P800 package using Switzer's Tial Alpha 28's.
Granted it's not a 68mm VTG, but these 28's spool within 100rpm's of the stock VTG's.
Old Jul 21, 2011 | 04:50 PM
MBailey's Avatar
These turbos are very close in spool and power production, IMO.
My car with A28s and EVOMS programming ran 5.54s 60-130 and a 997tt with 68mm VTGs from Champion ran a 5.50s.
Old Jul 22, 2011 | 10:52 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
For comparison's sake, here's the dyno of a car with our 68mm VTG's. This sheet is from an AWD Mustang dyno..but OK for comparison's sake.
Keep in mind also that VTG's will always be a much easier install, no cutting required. The also allow you to use factory ECU boost control, rather then an external boost controller (which could fail).
Old May 28, 2013 | 01:04 AM
Nardo4's Avatar
Nardo4 is infamous around these parts
Sounds fantastic!
Mathme
Cayenne 958
Mar 23, 2016 11:47 AM
COBB Tuning
Nov 3, 2015 08:39 AM
Emre@Esmotor
Oct 19, 2015 12:06 PM
vogz
Oct 12, 2015 08:46 AM
Oct 2, 2015 02:23 PM
