Disabling 6 disc on Durametric?
Old Aug 1, 2011 | 11:41 AM
997tttt's Avatar
997tttt is infamous around these parts
Hi.
Im looking to remove the 6 disk from my trunk to give me some more luggage space as I never use it anyway.
Howvever if I remove the 6 disk then the nav doesnt work - Something I use al the time.
Is there a way to disable this in durametric so I can remove the 6 disk and still use my nav?
Old Aug 1, 2011 | 03:35 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
You need to close the MOST loop. You can't just remove the changer without closing the MOST fiber loop. Once you close the loop your problems will be solved. Eric at bumper plugs might be able to help you with making a loop connector.
Old Aug 1, 2011 | 06:19 PM
Eric (Plug Guy)'s Avatar
Eric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond reputeEric (Plug Guy) has a reputation beyond repute
Yep, we can help.
CD Bypass/Closure cable, OR slam a Dension Gateway 500 in there and have iPod, Aux, USB and Bluetooth if you prefer!
eric@bumperplugs.com
Glasgo
Nov 30, 2015 02:37 PM
007 Vantage
Oct 8, 2015 08:35 PM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
Oct 2, 2015 02:23 PM
