Incomplete Brake Pad Contact on Disk Normal?
Old Aug 6, 2011 | 10:02 AM
Car-Narcissist's Avatar
Car-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond reputeCar-Narcissist has a reputation beyond repute
Message Removed
Message Removed
Old Aug 6, 2011 | 08:37 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
The "rust belt" looks thicker than I have seen. I don't think you have warped rotors - easy enough to check - gently go on the brakes and if the steering wheel shakes, chances are one or more are warped.
Old Aug 6, 2011 | 10:20 PM
TT Surgeon's Avatar
I highly doubt one trip to wig would result in a warped rotor.
I would start by replacing the pads on all 4 corners.
Old Aug 7, 2011 | 08:50 AM
Michael_s's Avatar
Michael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant future
Originally Posted by Car-Narcissist
I only have two reasons to suspect a rear warped rotor.
  • The steering does not wobble when the brakes are applied. Instead, there is just a woor-woor-woor sound from the rear of the car when braking.
  • I may have made the mistake of putting the e-brake on after one of the session runs (which I've read is not a good thing to do).
I'll get the car up on stands this week and put a magnetic base gauge on the rotors.
If you put the ebrake on there is a good chance you did some damage. The application of the ebrake does not allow the rotor to cool evenly resulting in warping. Common mistake the track...... Fortunately not too expensive to fix.
Old Aug 10, 2011 | 08:46 PM
PyroKerry's Avatar
PyroKerry has a spectacular aura aboutPyroKerry has a spectacular aura about
I get that uneven wiping when driving on the street sometimes. I wouldn't worry about it. Check it again after a day at the track.
Old Aug 11, 2011 | 12:33 AM
speed21's Avatar
You may need to consider if you have the right pads in the rear. The contact looks perfectly normal except it using only 9 tenths of the disc diameter. My money is on these pads being for a Carrera. It's amazing what some owners do to save $ whilst keeping a car roadworthy enough for sale purposes. Did you buy the car new? I'd do as TT surgeon says....replace the pads.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
rnl
Aug 26, 2015 02:36 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
