Fender well intake
For those who have implemented the fender well intake setup on a 997tt - 2 questions:
1. Are you also installing BOV's and if so, where? (I've seen some setups on the y-pipe and others on the ICs)
2. If you are installing BOV's are you doing so in addition to the stock diverter valves or are you somehow eliminating those?
You do not run the stock units with the after market bov .
Also to run after market bov venting to atm. You need a blow throug setup and tune or a mafless setup.
then take the stock ones out, and you can either buy a y pipe and have them put on there, or you can have some one mount them on the ic's.
I bought the latest IPD ypipe and plan to mount the new BOVs on it. My question is, can I simply remove the stock diverter valves from the turbos and fabricate a plate or something to cover the resulting hole from where the valves used to mount?
the diverter valves are on the top pf the motor towards middle .
yes , that whole area goes away once you put these on the ypipe and run vacume lines.
The diverter valves are located on the turbo's on VTG's so yes there would be a whole to cover ,it's when you switch to GT or Alpha turbo's that you use waste gates i'm pretty sure,did you get the blow through y-pipe like mine ,i'm running this set up with fender well intakes ,maffless & we had to remove the whole air box for this thing to fit in there .<a href="http://s1107.photobucket.com/user/twturbo/media/IMG_3827.jpg.html" target="_blank"><img src="http://i1107.photobucket.com/albums/h383/twturbo/IMG_3827.jpg" border="0" alt=" photo IMG_3827.jpg"/></a>
Do you have more pictures of your setup?
Sorry I got confused and then confused you. I'm just wondering if there are any big differences in setting this up on a 996tt versus a 997tt.
Sales@RSW
Sep 16, 2015 06:03 AM
997, 997tt, duct, ducts, fender, fenderwell, gt30s, inlet, intakes, intercooler, kuwait, oem, porsche, protomotive, turbo
