Exhaust tip options....
Well if thats the case then there really is no excuse to have all that farting going on. Its just downright rude
. So techarts it is then
Paul, isn't the Techart tip the one where one of the hole, the lateral hole, is blocked with a piece of metal?
Functionally it most likely doesn't matter, but conceptually the blocked hole could be bothersome to some. Just trying to help here.
Johnww, I have the Fabspeed for 2-3 years now, and maybe I misunderstand something, but I have no problem like what you described "carbon blackening"? It's a simple stainless steel finish, everything washes off no? And the soot comes out with such power and chaos, a "rolled lip" would reduce the mess?
I tried to find round tips with a rolled-lip, but no such luck unless I bought the entire exhaust like SpeedArt has. I just chose EP1 because of exhaustive 6speed-recommendations.
thanks,
my concern with the quad tips is the "connector plate" or piece that connects the dual tips together, being so apparent from the back. Here's a pic of the maxspeed nhp to describe what I'm talking about:
http://www.maxspeed-motorsports.com/..._i10_w640.jpeg
Anyone have any pics of the fabspeed and/or schnell's showing this angle to see if they suffer from the same thing?
-Jose
-Jose
Someone just addressed this in another thread (or another forum) - I'll see if I can find it.
They arent ever going to do a true dual pipe because of where the muffler is. You are just better off running a larger single pipe rather than 2 smaller ones.
I wish someone would make a cool looking single tip. There is NOTHING worse than a 1.3 engine with quads... or any type of fake tip. Even the ones with a bigger diameter after the pipe are lame. Different tips will make different sounds depending on flow. If you restrict it, make it "freer flowing in theory only" ( think bigger pipe), or make a "dual" and make some air flow farther all of that plays into the sound
