tiptronic mod????
Old Nov 12, 2011 | 12:28 AM
georgie's Avatar
georgie is infamous around these parts
tiptronic mod????
Hello to you all,
After spending hours of reading and confirming precious information around the forums regarding tuning of 997.1 turbo tip, I finally think I've found a stage that suits me for now. The mods I intent to do: Air filter, larger throttle body along with a larger diameter carbon Y-pressure pipe, modified GT2 turbos with larger compressor wheel (about 50mm), Europipe stage 1 exhaust, high flow intercoolers and of course ECU tune along with TCU. Based on my own knowledge the car will probably run at 1.3 bar or 19psi producing 630-640 hp. My worries are based on my transmission as some tuners reinforce it at that stage and others don't bother at all apart from a TCU tune. I would really appreciate your thoughts on that matter and If you could enlighten me with your experience this would certainly be a relief. I don't really want to risk my tranny at all. The car is completely stock for now...
Old Nov 12, 2011 | 12:54 AM
skeeter's Avatar
skeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond repute
I don't think you'll need to do your trans...When I started my search, Todd from protomotive, told me stay away from the gt2 turbos in a tip...He said there will be to much lag with them in a tip...He suggested a modified version of the standard turbos...G/l with your upgrades...What tuner do you have in mind?
Old Nov 12, 2011 | 01:18 AM
georgie's Avatar
Thanks Skeeter, I haven't decided the tuner yet... this package is just my own hardware preference. Regarding ECU and TCU tune this is going to be done by Jimmy from PP-Performance Germany. Very good ECU tuner indeed.
Do you thing it'll lag that much??? I think that a lot of tuners tried that, but I certainly don't know their client's opinion on the result. Some owners claimed 670-680 hp with those VTGs. I hope someone that did this VTG upgrade can share his experience though...
Old Nov 12, 2011 | 02:57 AM
PERONE78's Avatar
PERONE78 is a jewel in the roughPERONE78 is a jewel in the roughPERONE78 is a jewel in the rough
For tip upgrade the best is Emre!!
If you want I sell my EVOMS kit...
Old Nov 12, 2011 | 05:29 AM
besiktas's Avatar
besiktas is infamous around these partsbesiktas is infamous around these parts
better to go with hta 3071's rather than gt2 vtg's.. similar response, much more power. And carbon y-pipe won't give you much, I'd rather to buy a complete fenderwell intake kit. Much more efficient.
Old Nov 12, 2011 | 06:22 AM
Slow911TT68Tip's Avatar
Slow911TT68Tip is just really niceSlow911TT68Tip is just really niceSlow911TT68Tip is just really niceSlow911TT68Tip is just really nice
I had a 2008 997TT Tip with 68mm VTG's among other upgrades including the trans and it was very quick. So quick you could not shift manually. It was not TTS quick but I think it would surpass the TTS beyond 100 MPH. Definetely in the low 3 seconds 0-60 and low to mid 6 seconds 0-100. Champion did my car as they have several on the forum. As far as the transmission upgrade I think whiteknight (Emre) holds supreme.
BTW: My car was right at 675WHP.
Old Nov 12, 2011 | 09:39 AM
997 GT3 RS/TT's Avatar
997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute997 GT3 RS/TT has a reputation beyond repute
for big vtgs you should take europipe stage 2.
you should also think about air delivery for turbos...
Old Nov 13, 2011 | 01:45 AM
georgie's Avatar
3071 is certainly not a bad idea besiktas. Thanks. Also maybe you're right regarding intake. I considered also a GT2 intake although some tuners disagree with that and others love the idea. But I think that if you use 3071s you'll be needing connecting rods also for safety reasons apart from a tip mod...
Old Nov 13, 2011 | 01:51 AM
georgie's Avatar
I forgot to mention that my car is a cab... I'll be having some drone in the cabin with a stage 2 although it sounds great. My car is also a DD so I have to be careful with some things that restrict the car's everyday drivability...
Regarding air delivery for turbos what would you recommend?
Old Nov 13, 2011 | 02:44 AM
PERONE78's Avatar
The gt2 intake is smaller than the TT. If you want I have one OEM GT2 intake to sell.
Old Nov 13, 2011 | 03:41 AM
georgie's Avatar
Thanks! I'll let you know PERONE78. I also saw your PM... I can't reply though... I need some more posts to be able to do that... Thanks once again!
Old Nov 13, 2011 | 04:34 AM
John H.'s Avatar
John H. has a spectacular aura aboutJohn H. has a spectacular aura aboutJohn H. has a spectacular aura about
Does someone offer a fender-well intake kit? I've only seen this mod done with aftermarket ICs and Tial/Garrett turbos as part of a full "tuner kit".
John H
ggf
Sep 17, 2015 11:40 AM
Porsche951S
Sep 13, 2015 09:58 PM
Twinturbofan
Sep 11, 2015 04:14 PM
bobolouie
Macan
Sep 11, 2015 09:08 AM
