Center Caps/Lugs/Clear Markers
Old Jan 24, 2012 | 11:19 PM
SethW's Avatar
SethW is infamous around these parts
My car needs new centercaps and new lugs (where in the world they found these lugs is beyond me...look like off a model T) as well as some clear side markers.
First, which vendor is the best to work with for these products. I checked Suncoast and I did not see caps and lugs. Perhaps a call.
Second, does anyone with white have pictures of the stock type 1 wheels with the colored crests in the cap? I'm moving away from the amber side marker light, and i wonder if the colored crests would "pop" or just look out of place in my black and white world.
First mod complete, silver crest on the hood!
Old Jan 25, 2012 | 06:52 AM
jhbrennan's Avatar
You didn't look hard enough - usually under "chassis" then "center caps" and "wheel accessories".
http://www.suncoastparts.com/category/997TurboAA.html
Old Jan 25, 2012 | 07:37 AM
kalanis's Avatar
kalanis is infamous around these parts
I just got my clear side markers last night from Suncoast. Love um.
Old Jan 25, 2012 | 07:58 AM
SuncoastRyan's Avatar
SuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to behold
SethW,
We have side markers for the 997TT found here:
http://www.suncoastparts.com/product//clearsides.html
Center caps:
http://www.suncoastparts.com/categor...entercaps.html
Lug nuts we have the standard set and we can also get them in black:
http://www.suncoastparts.com/product...7TT_Wheelacces
Also if you are taking the wheels off your car may I suggest a wheel mount guide bolt:
http://www.suncoastparts.com/product/99957107430.html
These things are a big help and your back will thank you later. Well worth the 8.95.
Let me know if there is anything else we can help you out with.
Ryan
Suncoast Parts
877-923-1700
ryan@suncoastparts.com
Old Jan 25, 2012 | 09:15 AM
SethW's Avatar
Oops, bad searching on my part. I blame lack of sleep and moderate stupidity. Thanks for the help.
Old Jan 25, 2012 | 03:35 PM
dianic's Avatar
dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !dianic Is a GOD !
I agree with your thought Seth, the silver center caps would suit the white car better. Also do a search for a silver hood crest if any are still available. Eric had some a while back.
Old Jan 25, 2012 | 04:29 PM
SethW's Avatar
Silver hood crest was my first mod! I might get the silver center caps and then hand paint the red and black stripes, sort of a compromise, having some color, but still a silver palate...i will need to experiment on this.
Old Jan 25, 2012 | 04:31 PM
dianic's Avatar
Red nail varnish and a very narrow art brush. Have had similar thoughts!
A further idea is use paper tape to mask, and then a pin to tear the paper tape where you are painting.
Document with pics pls!
Old Feb 18, 2012 | 02:08 AM
Jsack's Avatar
Jsack is infamous around these parts
Ryan - I followed your instructions for replacing side markers on 2007 TT 997.1 and I am having trouble with the left one not fitting snug. It is so loose that a tap will knock it out. Any suggestions? Thank you.
Old Feb 18, 2012 | 06:31 AM
Michael_s's Avatar
Michael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant futureMichael_s has a brilliant future
Seth- How are you enjoying the car? I don't think you provided us with proper photos, unless I missed them. I recall the rear shot (behave) in the garage but your friends need more.......
Old Feb 19, 2012 | 08:22 PM
wasserson's Avatar
wasserson is infamous around these parts
Bend out the metal bracket
I had the same issue. I bent out the metal bracket, made sure the top of the metal bracket was bent approx. 100 degrees with the tiny lip bent up about 45 degrees. If you send me your cell number, I will text you a picture of the proper position before install!
Old Feb 20, 2012 | 05:07 PM
arash's Avatar
arash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to behold
Just a note: Be careful removing side markers. Most people try to pull them straight out from the wheel-side edge, and end up bending / breaking the metal clip and possibly damaging the mount slot too. The right way to do it is to slide it towards the rear of the car (by inserting and wiggling a soft plastic spudger on the front side gap) and then it should be easy to slip and lift out.
--arash
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Aug 19, 2015 06:35 PM
