Speed density Maf
Old Feb 5, 2012 | 01:15 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Speed density Maf
I am very interested in the Speed density and would like to know who produces/manufactures them?
I cannot find anything on the net!!
Old Feb 5, 2012 | 03:49 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Just pull out your maf and the car will run speed density automatically if that's what you mean.
Old Feb 5, 2012 | 04:08 PM
GTRNICK's Avatar
Hmm ok so there is no plug and play unit needed or available for the Porsche ?
Old Feb 5, 2012 | 04:14 PM
TTdude's Avatar
If you have a 997 turbo, the DME will switch over from maf to map.
Old Feb 5, 2012 | 04:16 PM
GTRNICK's Avatar
Is there a big benefit for doing this?
Old Feb 5, 2012 | 04:21 PM
TTdude's Avatar
Good question. In theory, for those pushing through a lot of air, removing the maf will allow for better flow. Just not sure how much better? Some say they can feel benefits with upgraded vtg turbos.
Old Feb 5, 2012 | 04:25 PM
GTRNICK's Avatar
What would you say are the negatives of doing this?
Old Feb 5, 2012 | 04:32 PM
TTdude's Avatar
I don't see any real negatives but others might. There are those who feel maf is the most accurate method of calc fuel/load but running off the map sensor is just as smooth on our cars. There are several on this board who are running mafless with vtgs and they seem happy enough not to put the maf back on.
Old Feb 5, 2012 | 04:35 PM
GTRNICK's Avatar
So maybe its a good thing to do when fitting larger aftermarket turbo kits when running serious horsepower, where you really do need all the extra airflow!
Old Feb 5, 2012 | 04:37 PM
TTdude's Avatar
Yes, I think that's where you would start seeing noticeable differences.
Old Feb 5, 2012 | 04:38 PM
GTRNICK's Avatar
Also thats probably when the Maf cannot keep up anymore.
Old Feb 5, 2012 | 04:51 PM
GTRNICK's Avatar
Thanks for the input TTdude
Old Feb 5, 2012 | 07:29 PM
TTdude's Avatar
Yeah and then you get into the situation when map can't keep up.
Old Feb 6, 2012 | 06:53 AM
PacMan Z's Avatar
PacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud ofPacMan Z has much to be proud of
When people run tial bov's or anyother for that matter, I always hear them say they are running speed density/maf. Is that how they are capable of using bov's because they no longer have mass airflow sensor running the car?
Old Feb 6, 2012 | 09:29 AM
TTdude's Avatar
BOVs have nothing to do with the type of tune you're running. It's a mechanical device to releases excess manifold pressure when you let off the gas pedal. For example, let's say you're boosting 1.5bar, then you suddenly close the throttle--the turbo is still spinning and that excess pressure needs to be vented or it will backup into the compressor and cause potential damage. The BOVs release that excess pressure.
