Questions abt Cat Bypass Exhaust
Subscribeexhaust for my Gen 1 997.1 Turbo, and hv been looking around Europipe, Fabspeed, and GMG. Just a few questions before purchase. Hope you guys could help.
If i purchase those cat bypass (Catless)
1. Will it trigger the Check Engine Light?
2. Would I be able to put my OEM exhaust back when I need to pass the emission test?
or should I get those cat??? Thanks!!!!!!!!!!!
1- Yes u will get check engine code with catless exhaust.
2- I guess yes you can.
Do u have a reflash ecu?
Quote:
Both r same. I believe u won't get check engine code since u have APR ecu.Originally Posted by rlau1288
I have the apr ecu...so wt I am required to do. What does reflashing ecu mean?
