Help with Durametric log file
Old Apr 5, 2012 | 07:58 PM
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
Originally Posted by MBailey
The map still is not what I am used to seeing with my pump tune, but timing is less shaky on this run 18 degrees and 1.4 bar is alot om 93 oct. I dont like how much the boost tapers at the top end from 1.4 down to 1.1 bar. This run looks very rich with lambas as low as 0.70 (afr ~ 10.3)...
I would consult your tuner and let him see the log and explain why the parameters are the way they are.
I will question about the lambda values. I've emailed APR about the boost levels prior to data logging, they were pretty on point saying max 1.4 bar and tapering off to 1.1 bar.
Old Apr 5, 2012 | 08:00 PM
Originally Posted by earl3
agreed, both the boost drop and fat AFRs may be indicative of a leak. In fact, it gets richer as the boost tapers. Logging MAF and setpoint boost pressure in addition to what you already have may shed some light onto it.
A boost leak or something else?
I tried looking for the setpoint boost pressure but didn't see it. Is it an available field with the 6.2 software?
Old Apr 5, 2012 | 11:48 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Using data from your first post. Looks pretty good to me.
Old Apr 6, 2012 | 07:11 AM
Is that the boost? Looks like a normal taper.
Thanks everyone for their help so far!
Old Apr 6, 2012 | 10:15 PM
TTdude's Avatar
No man, that's load vs rpm. Greater load = greater torque. You should put in some race gas and load up that 100 octane file. I'd be curious to see what your load curve looks like.
Old Apr 7, 2012 | 06:51 AM
Gotcha. I'll be doing some logging with 100 octane soon, just have to finish the 93 in the tank now.
Old Oct 15, 2012 | 02:56 PM
faiz's Avatar
faiz is just really nicefaiz is just really nicefaiz is just really nicefaiz is just really nice
Did u end up doing the 100 oct log?
COBB Tuning
Nov 3, 2015 08:39 AM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
Oct 2, 2015 02:23 PM
ek1
Bentley
Sep 27, 2015 08:38 AM
