Cooling hoses
Old Apr 21, 2012 | 08:53 AM
dysfunctional's Avatar
dysfunctional is infamous around these parts
Cooling hoses
Going to drop the engine as some coolant valve near manifold needs to be replaced. Where should I order the parts from (recommendations). Des anyone have a list of hoses and clips to order ? Since the engine is going to be dropped, I want to change all the coolant hoses, belts,...etc. Can any guru out here help me with what I should have done since the engine being dropped ?
Old Apr 22, 2012 | 04:53 PM
Steamboat's Avatar
Steamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond reputeSteamboat has a reputation beyond repute
You should consider replacing the glued in coolant hose fittings with fittings that are welded in place. It will avoid problems down the road.......Here are the ones I've had installed.
http://www.torquesolution.com/product-p/ts-por-001.htm
Best,
Old Apr 22, 2012 | 10:00 PM
Great...thanks....
BLKMGK
May 31, 2016 04:32 AM
BLKMGK
Sep 19, 2015 03:51 PM
dubl07
Cayenne 955/957
Sep 9, 2015 02:49 PM
