Considering new exhaust. Noticeable effect on lag? BMC questions too...
Old Apr 22, 2012 | 10:32 AM
farfel's Avatar
farfel has a reputation beyond reputefarfel has a reputation beyond reputefarfel has a reputation beyond reputefarfel has a reputation beyond reputefarfel has a reputation beyond reputefarfel has a reputation beyond reputefarfel has a reputation beyond reputefarfel has a reputation beyond reputefarfel has a reputation beyond reputefarfel has a reputation beyond reputefarfel has a reputation beyond repute
Europipe
My Europipe for 997.1 w 500 miles for sale.
Old Apr 22, 2012 | 11:56 AM
John@SpeedTech's Avatar
Originally Posted by L_Perm
John,
Thanks for the note. I'll call you. I wrote a nice long PM last night only to be told that I don't have enough posts to send a PM. I read your whole website and am intrigued.
LP
You're welcome, I look forward to speaking with you. Another option, if you wish to list some questions in writing is to email me, my direct email is info@speedtechexhausts.com
John
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
Old Apr 22, 2012 | 12:26 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
I like a good discussion, so don't take my response as anything other than my take on the issue off the top of my head.
This distinction seems semantic to me. If I understand, someone is making a distinction between the lag associated with overcoming the inertia of the turbo impeller and the lag associated with the time it takes a spinning impeller to compress the air to maximum boost. The VTG's address the first, but not the second. In fact, it seems possible that they may add to the second, given that the impeller blades have to open up, though this may happen very quickly. Please correct me if I've mischaracterized.
In any case, it seems the throttle response is non-linear due to the turbos. Whether or not you call the initial hesitation "turbo lag" is a decision concerning how one defines turbo lag, but it doesn't change the fact that there is an initial amount of acceleration upon opening the throttle at lower rpms, followed by a fairly abrupt increase in acceleration, and this phenomenon is turbo-related--as far as I know.
I guess it's possible with today's drive-by-wire systems that the initial hesitation is caused by the computer trying to decide if you really want to go fast. It wouldn't surprise me at all if that is some of the lag.
I would like to read what Bbywu has to say about it. I'll search around.
LP
No problem. On the surface it seems like a semantic argument but I believe there is a technical difference. That said, I'm not a turbo engineer just an enthusiast. I think of lag as the time it takes once the system reaches the boost threshold to max boost. Boost threshold is at what rpm and load the system is making measurable boost. Below the boost threshold, you're just building up to measurable boost. This threshold mainly depends on the aspect ratio (a/r) of the turbo. Vtgs have a variable aspect ratio depending on the load, rpm, etc...A smaller a/r will give you better low end rpm response and feel more responsive, less "laggy". A good tune will improve your boost response by adjusting the ECU to an optimal setting but even then it will be limited by the hardware of the vtg. So all things being equal, a vtg will not see the same early boost response as an A28 although there are probably some people on here that would argue with that.
Here's a good description http://www.mechanicalengineeringblog...-geometry-vtg/
Old Apr 22, 2012 | 05:26 PM
barca's Avatar
barca is infamous around these parts
ep
I'm on Montreal can I hear it in person
Old Apr 22, 2012 | 07:40 PM
thackl's Avatar
thackl is a name known to allthackl is a name known to allthackl is a name known to allthackl is a name known to allthackl is a name known to allthackl is a name known to all
Originally Posted by MannschaftQ8
E85 u will get great boost response, more power,more torque and cooler IAT!
Don't you need to upgrade the injectors for this?
Old Apr 26, 2012 | 09:16 PM
bbywu's Avatar
LP
I agree with Dave. There is lag, and boost threshold. What most people think is lag, is actually an artifact of the actual turbocharger's design - boost threshold.
If you change to a high flow exhaust, you will improve your lag. Will it be noticeable? Hard to say. But boost availability is dependent on the back pressure created by the exhaust system. The better flow in the exhaust (cat less, larger diameter) the more available boost.
An exhaust system's back pressure has the biggest influence on the pressure ratio across the turbine - the turbine needs to be able to do the most amount of work possible with the air coming into the inlet. For a given inlet pressure, you will get the highest pressure ratio across the turbine when you have the lowest possible back pressure.
The available boost is essentially inlet pressure minus back pressure.
Dave truthfully has more knowledge of this with his background and his hands on experience tooling his engine.
Old Apr 26, 2012 | 09:25 PM
bbywu's Avatar
Here's a link to a really good primer about turbocharging:
http://www.turbobygarrett.com/turbobygarrett/
Click on the "turbo tech" tab up top.
Old Apr 27, 2012 | 07:25 AM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
Originally Posted by Doc GTO
I have a Fabspeed V3 which sounds good. There are a few that sound good but I don't think any exhaust on the TT sounds great! The only way that happens is when you run straight pipes off the turbos!!!
This is as good of an assessment as can be made.
Our cars were not blessed with a cool, exotic sound, period. Some exhausts may make it sound slightly better. If you want the sound to blow you away and put a smile on your face every time, then you will have to run straight pipes or dumps. It will change the sound of the car drastically.
This post will help illustrate an easy fix of how you can use a Fabspeed system and make your car scream. There are photos and videos of outside and inside the car...enjoy. I suggest you get the Fabspeed so that you can have 2 different exhaust systems...
https://www.6speedonline.com/forums/...treatment.html
Old Apr 29, 2012 | 07:19 PM
cfpchfc1's Avatar
cfpchfc1 is infamous around these parts
Got my car back from getting modded a couple of weeks ago. installed Tubi, no cats + much more. Sounds incredible. No comparison to stock. It is still CPO, 2 years left. Champion did the work. If Porsche does not cover damage (should it occur), Champion will.
Old Apr 29, 2012 | 10:24 PM
porsche-driver's Avatar
porsche-driver is infamous around these parts
How much u selling it for?
tropicatango
Dec 4, 2015 02:45 PM
km90265
Aug 31, 2015 11:00 AM
gulf gt
Aug 27, 2015 10:27 AM
ritchrwi
Aug 21, 2015 04:36 PM
