997TT turbo problems
Old Apr 22, 2012 | 01:18 PM
Id4ever's Avatar
Id4ever is infamous around these parts
I seem to be having some issues with the turbos on my '07 997TT. Since yesterday it seems to have lost almost all boost. It never goes above 0.2 bar (3 PSI) according to the boost meter. It also feels like the engine's lost most of it's power above 2.5-3k RPM. On lower RPMs it feels more or less like it used to.
I can hear the turbos spooling up. In fact they seem to be much more audible than they used to be. It's kind of like a constant "psshhh" sound, similar to the sound that can be heard on some "riced" turbo cars with a dump valve. To me it sounds like the turbo boost is being vented into the atmosphere instead of going into the engine, but I'm no mechanic. Could it be a boost leak somewhere? Or does this sound more like stuck VTG actuators, which I hear is a common issue?
Old Apr 22, 2012 | 01:24 PM
bbywu's Avatar
Check your hoses to the intercoolers and your Y pipe.
Old Apr 22, 2012 | 01:28 PM
MannschaftQ8's Avatar
MannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the rough
Also make sure to scan it via Durametric cable
Old Apr 22, 2012 | 01:53 PM
svoshop's Avatar
svoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond repute
I agree with looking at the hoses. Sounds like you have a boost leak somewhere in the system. Maybe have a friend help by building boost while you listen to the source of the sound.
Mike
Old Apr 22, 2012 | 02:38 PM
997into's Avatar
997into is infamous around these parts
Sounds like Y hose leak.... I had same issue! Fixed with screwdriver
Old Apr 22, 2012 | 02:39 PM
floridaBMW's Avatar
floridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud of
Yep as was posted likely a boost leak. Pull the YPipe towards you, that was what came loose on me in the past. Gotta give her a good tug.
Ken
Old Apr 22, 2012 | 03:51 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
99% is a leak from a hose...when wastegates stuck you see around 0,8bar...check all hoses and also T pipe just after throttle body...(left and right black hoses feeding air to each cylinder bank tend to slip...)
Old Apr 23, 2012 | 05:33 PM
mr.porsche's Avatar
mr.porsche has a spectacular aura aboutmr.porsche has a spectacular aura about
i had the same matter in my mk2 turbo check ur y pipe and check the hoses for a vaccum leak
Old Apr 23, 2012 | 08:14 PM
CheriRone's Avatar
CheriRone is infamous around these parts
tropicatango
Jun 8, 2025 01:00 PM
Mark @ AIM Performance
119
Jul 28, 2021 08:07 AM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
