Misfire under boost
Old Jun 17, 2012 | 03:22 PM
MJA's Avatar
MJA
MJA is just really niceMJA is just really niceMJA is just really niceMJA is just really niceMJA is just really nice
What type plugs have you tried ? I have the IK-22 and now have a miss after 11K. I am going to go with the with IK-20,s or the double platluim.. Just dont want to keep paying $600 for a plug change...
Old Jun 17, 2012 | 04:10 PM
997TTMeister's Avatar
997TTMeister is infamous around these parts
I have only tried the ik22 and the factory plugs. After reading dozens of posts on the subject, I think the best bet is the Bosch OEM plug. RFR6DPP332 Cheap and the same as the Beru factory plug.
Old Jun 17, 2012 | 04:16 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Sounds like reset cleared everything. Wait and see kinda situation...
Old Jul 10, 2012 | 03:11 PM
Looks like the problem has returned as bad as ever. I don't think the reset will help this time as it is happening all the time under load.
Looks like it is back to the shop. I will get them to check the MAF.
Old Jul 10, 2012 | 11:14 PM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
A lot of folks claim that the one step colder plugs are better. Early last year I spent a few days calling a few pros and aggregating as much info/research as I could - conclusion: if you're in the 600-700 bhp range, go with OEM plugs. There's no evidence by any tuner (at least the three that I talked to) that claimed the others outperformed the OEM ones or vice versa. They have preferences - but there is no statistical evidence either way.
If some one does have controlled tests/results - I'd be interested, out of simple curiosity.
Personally, I've stuck with OEM's and all is good 12k in... and I'm no slouch on the pedal either.
BTW: my issues originated from faulty (stuck) turbo actuators, ate my plugs withing a few hundred miles, as well as some other issues due to raised backpreasure.
Old Jul 11, 2012 | 12:18 AM
I would agree with that assessment of plugs. And as my mods are similar to yours, i would agree that i fall into that category.
It is booked in for Monday, so my list of areas to check are now as follows: FPR, MAF and now the actuators.
Old Jul 11, 2012 | 12:32 AM
MannschaftQ8's Avatar
MannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the rough
We ran stock oem plugs on high 800whp cars for years with no issue.
Old Jul 11, 2012 | 12:36 AM
Did you pressure test your car yet?
Headers looks fine?
Old Jul 11, 2012 | 01:17 AM
Headers looks fine?
No i have not. The headers only went on 100 miles ago, so unlikely to have contributed.
Old Jul 11, 2012 | 09:34 AM
Slider's Avatar
I vote for a bad coil... I had a bad one and it caused very similar symptoms as you describe. One day I got so miffed at the hesitation, I just floored it when it hesitated - then it finally threw a code and told me what cylinder was misfiring. I changed the coil on that cylinder only and everything was beautiful from them on. I had lived with it for 4 months.
Old Jul 11, 2012 | 09:34 PM
MJA's Avatar
MJA
My car was in the shop today getting , oil change, double exhaust tips and plugs. My mechanic showed me how one of my coil,s had a small crack in it. So since he was in there I replaced them all. Car will be done tomorrow, Looking forward to it. Keep in mind the only miss I had was at high boost. The ik22 plugs looked bad with worn out electrodes.... 11k on them..
Old Jul 12, 2012 | 07:32 AM
Unfortunately last time the misfire followed the plug when things were swapped.
Old Jul 12, 2012 | 09:50 AM
MJA's Avatar
MJA
Did you happen to inspect the coils packs for cracks ?
Old Aug 13, 2012 | 04:54 AM
Further development, but still not resolved.
The car is running lean. The MAFs have returned incorrect voltage, so they need to be replaced.
Get this. They wont warrant the MAFs due to the BMC filter. WTF! I have ordered some Bosch replacement units for less than have the price.
They better replace the plugs they installed after false diagnosis or I will be completely p!$$ed.
Old Aug 13, 2012 | 07:10 AM
Flash it with stock file then scan it. New codes may appear!
