Misfire under boost
Old Aug 13, 2012 | 10:14 AM
  #31
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Originally Posted by 997TTMeister
Further development, but still not resolved.
The car is running lean. The MAFs have returned incorrect voltage, so they need to be replaced.
Get this. They wont warrant the MAFs due to the BMC filter. WTF! I have ordered some Bosch replacement units for less than have the price.
They better replace the plugs they installed after false diagnosis or I will be completely p!$$ed.
Just run mafless. Make sure your plugs are gapped correctly or else you will continue to have misfires. Talk to you tuner on what he recommends.
Here's a good quick read--
http://www.neuralblog.com/_content/P...-707_pn-1.html
High performance plugs, for tuned Porsche 997 Turbos
The following High performance plugs, for tuned 997 Turbos are recommended:
  • Best reccomended plugs are the: PK20PR-P8 Denso. Close the gap to .025" for higherboost levels.
  • The NGK equivalent of stock number 2667 of BKR7EIX is also recomended and used in many of the high horse power Porsche 997 Turbos. The Denso also works well.
  • Ruf apparently run the "Beru Ultra 14 FR-6-LDU" plugs on their 550 Rturbo.
  • Stock OEM for the 997 Turbo being the Bosch FR6DPP332 spark plugs.
For Turbo's running under 650hp (crank), OEM plugs may be used and life expectancy would be the same as that of the Denso and Beru mentioned above. Once you start venturing into the higher horse power applications it would be recommended to change up to the "one stage colder" plugs (mentioned above) as replacement to the Bosch OEM plugs.
Old Aug 13, 2012 | 11:38 AM
  #32
gmoney's Avatar
Have you cleaned and re-oiled the filter? Curious if a stock oiled one may have fouled the sensors vs. a user cleaned one.
Old Aug 13, 2012 | 03:08 PM
  #33
997TTMeister's Avatar
997TTMeister is infamous around these parts
Originally Posted by MannschaftQ8
Flash it with stock file then scan it. New codes may appear!
Are you suggesting there could be something more sinister than the MAFs, which will show up on the stock flash?
Old Aug 13, 2012 | 03:11 PM
  #34
I just took it out of the pack and stuck it straight in. It has been in for about 2000 miles. Do you think the oil from the BMC could have fouled the sensors?
Old Aug 13, 2012 | 03:14 PM
  #35
I disconnected the sensors for the drive back from the dealer, but there was no difference. The plugs might be past it.
I have read that article it is quite helpful. I am running standard plugs with standard gaps at the moment.
Old Aug 13, 2012 | 06:21 PM
  #36
TTdude's Avatar
Install the Denso PK20PR-P8 and gap to 0.025". That will work well with your tune. If your gap is too wide then you will get misfires at wot/high load/high boost. With a flash, be prepared to change your plugs a lot more frequently for optimal performance.
Old Aug 14, 2012 | 04:55 AM
  #37
MannschaftQ8's Avatar
MannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the rough
Could be. Some codes won't show with flashed file
Go back with stock file then scan it again.
Old Aug 14, 2012 | 08:20 AM
  #38
gmoney's Avatar
Doubt it on a fresh filter but likely if user cleaned and too much oil is used.
Old Aug 14, 2012 | 09:27 PM
  #39
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
excellent info here
Old Aug 14, 2012 | 10:25 PM
  #40
I have confirmed with the tuner, and they recommend 0.025" plug gap for my mods. MAFs have been ordered, awaiting for delivery.
Old Aug 20, 2012 | 03:36 AM
  #41
It looks like Bob was right with the MAF suggestion. There was definitely a lean condition. I ran with out MAF sensors whilst waiting for the part, and the misfiring reduced over time. I now have the new MAFs in and the car is going even better again.
Not sure if the plugs will still need replacing after no more than 600 miles with the fault. I will check with the dealer and see how it goes.
Thanks guys.
Perkman87
Nov 19, 2015 05:31 PM
Emre@Esmotor
Oct 19, 2015 12:06 PM
whtrabt
Oct 5, 2015 05:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
