ECU / Exhaust question
Old Jun 23, 2012 | 01:10 PM
nflpats's Avatar
nflpats is infamous around these parts
I just installed a cat bypass pipe x pipe exhaust this past week. I would like to know if an ECU flash is required? I have bigdaddiesgarage O2 sensors so no CEL lights appear. nly concern is whether or not it is safe to run this exhaust without a flash to change or correct the air fuel mixture. I dont want to harm the engine should it run lean. Any suggestions? Thx
Old Jun 23, 2012 | 08:22 PM
Panguard's Avatar
Panguard is infamous around these parts
Running an exhaust without a tune should always be fine. But you should only get a tune if you want more power extracted to compensate for the added exhaust.
Some people only buy hardware and never software so go figure.
Old Jun 23, 2012 | 08:39 PM
nflpats's Avatar
I'm planning on getting the software, just wanted to make sure no harm would be done in the mean time. Thanks.
Old Jun 23, 2012 | 10:13 PM
zippsub9's Avatar
zippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud ofzippsub9 has much to be proud of
Turbos, unlike naturally aspirated engines, don't need the backpressure from exhaust and love to run wide open. You will not harm anything, if it were not a Turbo you would probably still be okay. Only when you start talking about drag pipes or just enough off the header to get the heat past the bumper do you start to worry about bending valves.
Jul 29, 2019 11:13 AM
Sep 14, 2015 06:42 PM
Sep 1, 2015 03:16 PM
Aug 20, 2015 12:17 PM
Aug 19, 2015 06:55 PM
