Need help after replaced actuator low boost!
Old Jul 5, 2012 | 08:32 AM
Markusssss's Avatar
Markusssss is infamous around these parts
Hi Guys,
I've recently had the dreaded seized actuator replaced on the passenger side of my car.
I literally parked it up and it was fine and the next thing I knew I had no boost whatsoever.
So the garage diagnosed the actuator, replace and programmed it. Since I've had the car back I only boost to about 0.6 bar max and the car still doesn't feel right.
Its been back to another garage and they have driven the actuators manually and checked the actuator rods and all seems ok. They have also checked for any boost leaks and haven't found any.
Has any one got any more ideas why I'm not boosting properly? The car runs fine otherwise with no smoke or anything like that.
Cheers
Mark
Old Jul 5, 2012 | 07:01 PM
bumperpip's Avatar
bumperpip is infamous around these parts
No codes ? PIWIS/Durametric ?
Old Jul 6, 2012 | 12:42 AM
Markusssss's Avatar
No codes at all, everything is clear dude.
Could it be the electronic boost valve?
I did find a thread on here where another guy had the same problem and changed the turbo boost module which I'm assuming is the actuator?
They shop is going to check the programming of the actuator on Tuesday. I've also checked for boost leaks and have found nothing and had 2 different garages check also
Old Jul 6, 2012 | 12:53 AM
Markusssss's Avatar
Jul 29, 2019 11:13 AM
BlackMarketRacing
Dec 8, 2015 01:49 PM
r_matt_6
Oct 8, 2015 06:07 PM
gulf gt
Aug 27, 2015 10:27 AM
TrackOne
Aug 20, 2015 12:56 PM
