What tires??? Need help
Old Jul 26, 2012 | 09:49 PM
meaker's Avatar
meaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to beholdmeaker is a splendid one to behold
Originally Posted by johnmiller
Try Michelin. i hope it will fix your problem.
did you read the first post? Michelin stop making the 245/30/20
Old Jul 26, 2012 | 09:54 PM
meaker's Avatar
Originally Posted by MBENZF1
245/30/20 & 325/25/20 seem to be bull**** sizes, I'm having the same problems you guys are. Pirelli discontinued the tires, I have Conti DW's on the rear but can't find the fronts because Conti discontinued the fronts. Not sure what is going on with Michelin, and don't want Hancooks.
Damn so Conti discontinued the fronts too?? I was going to try find them.. This is just insane.
How many here are trying to put tires on a set of forged $5k-10k?? I feel like we either have to junk these costly rims or run some mismatch tires. Neither one is a good answer..
Old Jul 26, 2012 | 10:41 PM
swole305's Avatar
swole305 has a spectacular aura aboutswole305 has a spectacular aura aboutswole305 has a spectacular aura about
i am - was birthday gift to self almost 4 months ago and no tires...
Old Jul 27, 2012 | 05:45 PM
damon@tirerack's Avatar
Moderator
Originally Posted by 512bb
They cannot ramp up the Pilot Super Sports as a replacement for the PS2 until they get the N rating and as far as I know, they have not received that designation yet.
Michelin will keep producing N rated Porsche-sized PS2's for quite awhile. They will probably be contractually obligated to do so. I don't have word on when/if PSS will be N rated but I suspect eventually they will. The 20' combo is definitely a conundrum combo. The market really wasn't ready for this combo outside of OEM tires.
It's a lot like trying to find 315/25 19 and 235/35 19 tires for the 996. Gone like Kaiser Soze...
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jul 29, 2012 | 02:13 PM
alexo's Avatar
alexo is a jewel in the roughalexo is a jewel in the roughalexo is a jewel in the roughalexo is a jewel in the rough
lol shoulda got some 19" HRE **** me
Old Jul 30, 2012 | 04:03 PM
TAGMotorsports's Avatar
TAGMotorsports is infamous around these parts
Guys,
This is a HUGE issue, the 245/30/20 Michelin's are nowhere to be found, and the 325/25/20 Pirelli's are nowhere to be found...
HOWEVER - There is a light at the end of the tunnel. Pirelli has just received the molds from Germany to build the 325/25/20 PZERO here in the States. We have purchased the first batch of tires which will be available within about 60 days or so. Stay tuned for updates...
Thanks,
Alex@TAGmotorsports.com
Old Jul 30, 2012 | 04:10 PM
swole305's Avatar
any news on the front 245/30/20?
Old Jul 30, 2012 | 04:14 PM
meaker's Avatar
So could you run a 255/30/20 on the front? The dia 26.1 compared to 25.8 on the 245/30/20. Is that too much of a difference? The rears are 26.4
Old Jul 30, 2012 | 09:07 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Based on my calculations and assuming you run the 325/25/20 rears, you WILL have issues with the transfer case. The stock F/R ratio is 97.22%, with the 255-325 combo your F/R ratio will be 98.58%. I also have empirical data on this as I tried almost the exact same F/R ratio of 98.59% and the transfer case (as well as the PSM) where having issues. Can go into more detail if there is any interest.
I can into how I came up with my calculations if anyone is interested (and for peer review).
Hope this helps.
Cheers.
Old Jul 31, 2012 | 09:30 PM
meaker's Avatar
Hope this helps.
Cheers.
Thanks for the info. It's amazing that it doesn't take but a lil to throw off the transfer case. we are olny talking .3 of a inch taller. Seems like you would have problems with this when your rear tires wear down faster then the fronts.
Old Aug 1, 2012 | 06:28 AM
512bb's Avatar
If my calculations are correct (since Porsche does not give that information to mere mortals) the tolerance is only around the depth of the thread for stock tires, which is in line with Porsche's recommendation to change all four. Now that tolerance limit goes down if running non-stock tires.
Old Aug 1, 2012 | 04:22 PM
hjacobs2000's Avatar
hjacobs2000 is infamous around these parts
So I also have the same issue with not being able to get tires for the above mentioned sizes for my 09 Turbo. That being said, what 20" wheel size should I get now to have tires (preferably Michelin) that are readily available. My wheel manufacturer will resize the barrels up or down to meet my needs.
Old Aug 2, 2012 | 04:29 PM
512bb's Avatar
One set of tires for sale on Rennlist under the thread "Complete 997TT Consignment Part Out - HRE Wheels, Brembo Brakes, Speedart Aero Kit".
Thought you guys might be interested.
Old Aug 3, 2012 | 08:11 AM
meaker's Avatar
Yea those are long gone.. thanks anyway
Old Aug 6, 2012 | 02:01 PM
bump
