Blue demon from Russia with love :)
SubscribeQuote:
How does it ride in traffic?
A little big laggy, but okay Originally Posted by ice350
Love when guys post the dyno sheets with the pics.How does it ride in traffic?
On pump gas 1,45 bar (21psi) it has 908Hp and 997Nm on crank
^this is on 35s already? good power. 720 whp? when are you turning the boost up. i made about same power on my 30s.
Todd from Proto usually recomends .82 and not the .63 on the HTA... why did you go with the smaller one?
Nope! 1020hp or 820whp on HTA3076 0.82Originally Posted by prodigymb
^this is on 35s already? good power. 720 whp? when are you turning the boost up. i made about same power on my 30s.Todd from Proto usually recomends .82 and not the .63 on the HTA... why did you go with the smaller one?
For gtx3582 only one reason in 0.63... Not to loose much in spool, cuz it's DD car
New turbos in work now
Are you using GT turbine housing?Originally Posted by MegioN
Nope! 1020hp or 820whp on HTA3076 0.82For gtx3582 only one reason in 0.63... Not to loose much in spool, cuz it's DD car
I though you have straight Alpha 3076
Quote:
Tial Alpha hotside is a small direct bolt on hotside for Porsche. It is not .82AR. Tial does have some other stainless hotsides .63 and .82 for the 30.dOriginally Posted by MegioN
It's hybrid of hta3076 and tial alpha hot side 0.82
Do your turbos have external wastegates or internal?
Internal. Turbos was sent directly from Todd, he told me that's HTA3076 with tial alpha hot side, not only compressor wheelOriginally Posted by prodigymb
Tial Alpha hotside is a small direct bolt on hotside for Porsche. It is not .82AR. Tial does have some other stainless hotsides .63 and .82 for the 30.dDo your turbos have external wastegates or internal?
Megion
Check your PM!
Check your PM!
Quote:
GTX3582 0.63
Proto custom headers with ex WG
Proto custom straight 4" exhaust
Wow..Those pipes looks LOUD!Originally Posted by MegioN
Some new mods! 1400hp systemGTX3582 0.63
One more thing..Those GTX35's will wake up ( REALLY perform ) only from 28-30psi and above. So don't waste your time testing less than ( 28-30psi )
It's not problem in Russia with loud exhaust, I can drive it daily Originally Posted by MannschaftQ8
Wow..Those pipes looks LOUD!One more thing..Those GTX35's will wake up ( REALLY perform ) only from 28-30psi and above. So don't waste your time testing less than ( 28-30psi )
))And I know about this turbo, target boost is 30psi
I have read about p3402 problem, and only one reason why it can happen is overheat.
I make some logs, IAT was at start 65 Celsius at finish 109!!!
What it can be? Not effective IC or too restrictive exhaust?
Why not more than 30psi?Originally Posted by MegioN
