08 997tt wheel vibration issues
Old Aug 11, 2012 | 07:31 PM
cfpchfc1's Avatar
cfpchfc1 is infamous around these parts
Unhappy 08 997tt wheel vibration issues
Hello, Everybody.
I got my wheels balanced a couple of times to the gram and still, above 75 mph, I feel rumble and vibration from front and rear . road force was below 24 for all tyres
My set up is:
OE wheels, polished to bear metal.
Potenzas tread 9/32 front, 7/32 rear.
Spacers, 7mm front, 14mm rear.
I tried a set of different set of wheels with michelins and worked perfectly.
Trying to pin point cause: wheels, tires or spacers?
Any suggestions are appreciated.
Old Aug 11, 2012 | 07:37 PM
BigBen97's Avatar
BigBen97 is a jewel in the roughBigBen97 is a jewel in the roughBigBen97 is a jewel in the rough
Did you use the spacers when you tried the other setup?
I just had my rears rebalanced and they still aren't perfect but I want to make it through the next couple months with these tires until the spring. Mine are close the wear bars though.
I would try your setup without the spacers to see if that helps if you can. At least it will rule out one more variable.
Old Aug 11, 2012 | 09:52 PM
kitw's Avatar
kitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud ofkitw has much to be proud of
Make sure the shop is using a road force balancer. The Hunter GSP9700 is the standard. I've seen bad spacers cause this, but it's usually just a failed balance - spacers make the balance more critical.
Old Aug 12, 2012 | 07:23 AM
cfpchfc1's Avatar
Good point, no spacers with the previous set up.
Old Aug 12, 2012 | 07:25 AM
cfpchfc1's Avatar
They do. thanks
Old Aug 12, 2012 | 11:33 AM
kitw's Avatar
Originally Posted by cfpchfc1
They do. thanks
If they are vibrating, I would suspect your spacers. Try pulling them off. What I've found is that spacers exacerbate any small wheel issues... usually spacers and new wheels / tires are fine, but even a tiny little bend in the wheel will be magnified with spacers.
Old Aug 12, 2012 | 11:36 AM
cfpchfc1's Avatar
I will. Let's see what happens...
COBB Tuning
Jan 1, 2025 09:02 AM
Mark @ AIM Performance
119
Jul 28, 2021 08:07 AM
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
