GT RS Front Fender Extension on Turbo Bumper
It seems that are out there some turbos with the RS fender flares on stock bumper but none posted pics so far or shared the experience. GT2 and GT3 has the same rear parts numbers of the flares but different parts that are attached to the bumper. Which will fit better on the turbo bumper, GT3 RS or GT2 RS?
I'll be doing this mod pretty soon ,i found a set of the full carbon fiber fenders from a gt2rs on ebay already painted my body color for a great deal,the only thing i need is the new side marker lights & this lower piece of the fender extension kit .My shop & i figured this piece will need some customization to fit a turbo bumper,i did check with the dealer on this piece but didn't realize the gt3 & gt2 where different part # here's some close ups i've taken gt2,gt3,tt ,i think i think the gt3 will fit best but either one needs to be customized.
I installed the front fender extension..but dosent fit well..as you can see in my fotos ...i am already searching for a front bumper from GT2/2RS to solve the problem
(It seems that are out there some turbos with the RS fender flares on stock bumper but none posted pics so far or shared the experience. GT2 and GT3 has the same rear parts numbers of the flares but different parts that are attached to the bumper. Which will fit better on the turbo bumper, GT3 RS or GT2 RS?
From your pic the turbo bumper seems to be higher than GT2/3 bumper and therefore than fender extension parts.
The problem with the GT2 bumper is that it isn't a simple install. All the ducting behind the bumper is different.
I think it is more affordable to ask to a paint shop to make a little customization to make it look good, than make the GT2 front conversion. But imho, the GT2 front look wins over the turbo.
First of all, thanks for the pic. Do you have GT2 or GT3 fender parts?
...i will let you know
i have the GT2 fender parts..i know that is not easy to install the GT2 bumper...but i agree with you ..the GT2 front is much much more beautifull....till next week i will solve the problem as my car tomorrow going to a workshop for some more body mods
I had a 996TT and successfully installed the 996 GT2 bumper without issue. It was a direct plug and play. The 997 GT2 front bumper is not a direct bolt on? Interesting.
Adam
Adam
I forgot to ask you what is your spacers setup, 15mm rear and 7mm front?
The front wheels also shows a agressive camber setting. Is it GT3 settings? How it handles and what is the tire wear with that setting?
Polyurethane or fiberglass material? Just the bumper part or complete piece? Do you have set already the price?
Edwin
yes ..the camber setting is quite agressive..but is depence the driving style...for me and for the use of the car is ok
...is feel like a gt3(as i had a gt3 heavy tuned and i knw the feeling preety well)but a bit heaver..much better than stock..but i still prefer the gt3 feeling..maybe i miss the rwd..
...i have a manthey racing suspension with clubsport kit(strut tops,spring cap,wishbones CUP,tension strut CUP ,etc etc)
But you forgot to tell me what is your spacers size, front and rear?
Thanks for posting the pic GreekM3 & being the 1st to try this ,but something looks wrong there ,it looks like they cut the extension piece down it just looks too short ,they cut the whole bottom part off instead of customizing it to fit the tt bumper ,which is what i was thinking was possibleyou can clearly see the gt2 piece makes a 90 degree turn at the bottom
