electric seat stopped working
Old Nov 8, 2012 | 07:19 PM
ERSKATEDOC's Avatar
ERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to behold
The controls for my drivers seat stopped working. The lumbar support still works, but the seat memory only moves the mirrors to their saved position. The front/back, up/down, and seat back forward/backwards buttons at the seat base do not respond. The passenger seat works fine.
Any suggestions? I figured if it was a fuse, the lumbar support should be out as well as the passenger seat.
Its under warranty - just dread going to the dealer.
Old Nov 9, 2012 | 08:42 AM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Plug it in man, plug it in :-) Just kidding.
Look under the seat, there should be a big yellow plug, try and see if that became disconnected or dislodged and more importantly check the wires to see if any of them have been caught in the tracks, or snagged on anything.
Old Nov 9, 2012 | 09:59 AM
ERSKATEDOC's Avatar
Ok - I can see the plug, but the seat does not lift, so it was really tight getting my hand under the seat. The plug was in, jiggled it a bit- no luck. Wires appeared ok and not frayed or cut.
However, popped off the fuse panel and read the fuse panel configuration book - turns out the right and left seats are on different fuses. Swapped the fuses for the seats (R & L) and now the drivers seat works and the passenger is dead.
Off to pep boys for a new fuse.
Whew - that was too easy - just hope it does not blow as well.
Mike
Old Nov 9, 2012 | 10:26 AM
gmoney's Avatar
That would have been a $200 dealer visit!
Old Nov 10, 2012 | 04:57 PM
512bb's Avatar
Glad it worked out and hopefully the fuse does not blow again indicating a short. $200 would only get you a diagnosis at my dealer!
cnebrask
Oct 3, 2024 08:19 PM
Michael_s
Sep 11, 2015 08:03 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
The Oss
Aug 24, 2015 08:19 PM
saline
Aug 19, 2015 12:25 PM
