Power on pumpgas with Alpha3076 vs VTGs...
Old Dec 25, 2012 | 10:30 PM
  #46
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
I think to hit 1.9 bar on vtgs you have to trick the pressure transducer since it pegs at 1.55. I believe the 63.5 mm vtgs can hit 1.9 as well. I remember Kercar hitting 5.5s (60-130, stock weight) and it was an amazing time. IIRC, he even said he had a passenger which was even more amazing. At 1.9 bar, this helps explains things. As Boggster said, no one to my knowledge has repeated this with any vtgs but haven't been tracking things that closely.
Old Dec 28, 2012 | 07:33 AM
  #47
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Originally Posted by The Bogg
ummm...was the software modified by someone? Tom clearly stated that the GIAC tune is set at 1.5bar max if I am understanding correctly. If not, then I'd be interested in knowing if the 5.5s run (KerCar) was at 1.5bar or 1.9bar b/c if it requires 1.9bar then I'll pass on it. Otherwise it is something I'm still considering. Damn I wish more people had some numbers on the 68vtgs but everyone that said they were going to provide pbox numbers on them ended up selling them or just not posting anymore. I'm not reading into that too much but it does concern me considering it will be close to a 10g investment when you factor in turbos, intake pipes and installation costs.
Hey Pascal, getting low 5s (100-200) on those vtgs is amazing. I may check with Todd about a version of that tune for me in the spring!
I can tell you that there are no Champion kits out there running anywhere close to 1.9 bar with our turbos, except on cars with built engines. Our standard GIAC software does NOT allow for 1.9 bar.....exactly how KerCar hit 1.9 bar is beyond me...unless the software was modified.
In fact, I talk to KerCar regularly, and this is the first time I've ever heard any mention of 1.9bar in his car with our turbos on it. Realistically, from the time I shipped him his ECU to the time he did the 5.5 sec run was only a matter of maybe 2 or 3 days...and that includes the transit time to Turkey. So...I'm confused.
Old Dec 28, 2012 | 07:46 AM
  #48
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Hello Tom,
We didn't touched the software or anything else on KerCar's VTG setup.
Kerim (owner) was also surprised after seeing the car boosting 1.9 bar with Giac Race file.
I think that it's not possible to get 60-130mph in 5.5sec with 1.5 bar boost.
I also think this is related with the Forge Motorsport diverter valves on the car.
It might have the stiff springs inside which obviously can results in high boost.
You can also talk with Kerim about this.
However, i was really happy with the performance of your 68mm VTG's.
I saw these turbos also performing well in one of my Greek customers car.
Thumbs up for good performing and good quality product.
Cheers,
Emre
Old Dec 29, 2012 | 01:22 PM
  #49
TTdude's Avatar
I think this is speaking the truth. Good for you Emre. How did you measure the boost (1.9 bar)?
Old Dec 29, 2012 | 04:33 PM
  #50
BaldBag's Avatar
BaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant futureBaldBag has a brilliant future
Would be nice if we could swap out the Map sensor or Pressure tranducer for a 5 Bar like on the GTR
Old Dec 29, 2012 | 10:57 PM
  #51
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
VTG turbos? What spec and what result?
I am interested in what HP has been achieved with VTG's-any answers?
What is the possible using VTG as base? (either GT2 or Turbo)
Old Dec 30, 2012 | 01:19 AM
  #52
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
Originally Posted by pete95zhn
Here's some compressor wheel flows:
65HTA - 43 lb/min
68HTA - 47 lb/min
Multiply those with 9.5 and then again with 2 and you'll know how much VTG turbos can produce in correct housings and tuning. Max crank hp in optimal conditions.
Ie biggest or most efficient -so far- available wheel for a VTG turbo is that 68HTA which also requires a new compressor housing. It will max out around 445hp, which means theoretical total of 890 crankhp in optimal conditions.
Old Dec 31, 2012 | 12:51 AM
  #53
There was an HKS boost gauge in the car, which was connected directly to the intake manifold.
Old Dec 31, 2012 | 12:53 AM
  #54
3 bar is possible, but im not sure about 5bar, i have to try
Old Dec 31, 2012 | 01:38 AM
  #55
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Isnt 3bar close to 44psi, who would ever need more?
Old Dec 31, 2012 | 04:06 AM
  #56
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
It is very difficult if not impossible to fully control the boost on the VTGs, on my car i have different boost in every gear, i think the maximum i have noticed is 1,6 Bar in 4th gear
Old Dec 31, 2012 | 04:22 AM
  #57
pete95zhn's Avatar
Totally untrue, difficulty in controlling boost has nothing to do with VTGs themselves. With proper aux unit one can have gear dependent boost with VGTs too. The problem is the lack of proper unit...
Old Dec 31, 2012 | 05:10 PM
  #58
Red 9's Avatar
Thx for previous answer!!
Can you explain more here please?
I am interested in the plusses and minus's of using VTG--I have reasons to use them-- so trying to understand what is possible and impossible.
It is obviously easier to go other tried and true directions and knowing the comparatives is not so easy to follow.
Old Jan 1, 2013 | 01:18 AM
  #59
milou's Avatar
I would like to hear a tuner explaining how the boost can be fully controled on VTGs , also Tom should explain the 1,9b on their 68mm :-)
Old Jan 1, 2013 | 02:45 AM
  #60
pete95zhn's Avatar
With a unit that has gear dependant boost control and certain type of programmable output(s) it can be done. Problem here is that to get both of those features you'll (just now) need either Syvecs or ProEFI Pro128 (or similar unit) standalone...pretty expensive for just boost control. So far I haven't found any boost controller that has all required features for that.
In addition to that hardware you'd need a tune for Motronic that understands higher boost leves and disables certain VTG contol/feedback features (for not getting CELs).
I'm not a tuner (just a D-I-Yer ), but have electronically controlled VTG turbos in a 996 turbo engine (independent of ME7.8) and can set another one to 0.5 bar and another one to 1.5bar...just for example, no sense to do that though... My controller has dual programmable outputs and within the range of compressor map I can set a boost level I want. It's just can't do it gear dependent.
PS: IMO pneumatically controlled WGs are so last season...
