SpecG 997.2 Turbo S
Old Jan 11, 2014 | 10:29 AM
  #31
SpecG's Avatar
SpecG is infamous around these parts
Originally Posted by isysman
your car looks good and clean. its what i originally wanted.
do you really want the fenders? gonna be frankenstein?
Old Jan 11, 2014 | 10:35 AM
  #32
SpecG's Avatar
Notice I havnt really shown the photo of the rear of the car.
Its because the Akrapovic tail pipes for the Turbo S wont fit with the GT2RS rear bumper.
I have ordered the Akrapovic GT2RS tailpipes and I will see how I can get it to fit on to the Akrapovic Turbo S exhaust. Its going to need custom work for sure
ID:	320172   Click image for larger version
Old Jan 11, 2014 | 11:00 AM
  #33
sideWays_swe's Avatar
sideWays_swe is a jewel in the roughsideWays_swe is a jewel in the roughsideWays_swe is a jewel in the rough
Awesome Awesome work! The car looks great!
Old Jan 11, 2014 | 01:28 PM
  #34
isysman's Avatar
isysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond repute
Yes I knew about this. I bought a set of GT2RS titanium tail pipes for when I have my rear converted to GT2RS. I'm just waiting for my bumper and carbon parts to arrive. I already have the lights and other parts.
I want to complete the look as you have done as the GT2RS is my favourite car but I'll never be able to afford one do this will be the closest I can get.
Why do you say the GT2RS has better aerodynamics than your car, you have all the same bodywork and wheels now?
Old Jan 11, 2014 | 01:38 PM
  #35
isysman's Avatar
Do you have any photos of how the new radiator and ducting looked after you changed them to GT2RS ones?
The way the airflow through the front radiator and out on top for the GT2RS/GT3RS requires different radiator frame with a built in air duct to direct the hot air upwards. This design requires that the radiator is mount slanted to allow optimum airflow.
New radiator is needed as the water inlet/outlet ports are at different angle due to the way its mounted (ircc)
Old Jan 12, 2014 | 07:01 PM
  #36
SpecG's Avatar
This is with the GT2RS radiator mounted with (incorrectly) Turbo S air inlet duct. Also GT2RS outlet duct is lying on top of the car uninstalled.
Here is the GT2RS radiator frame with the built-in air ducting channel.. and GT2RS radiator hoses
ID:	320608   Click image for larger version
Old Jan 12, 2014 | 07:04 PM
  #37
SpecG's Avatar
Here is a picture of the headlamp washer mounting that I had to custom because Porsche cant seem to be able to find the correct parts for me. Anyone know the proper way to fix this issue I have? How does the OEM GT2RS mount the headlamp washer?
Old Jan 12, 2014 | 07:08 PM
  #38
SpecG's Avatar
My new IPD Y-Pipe and OEM air filter.. looking very OEM now
Old Jan 12, 2014 | 10:07 PM
  #39
theDIMAS's Avatar
theDIMAS is infamous around these parts
Very nice work. Looks like your shop is top notch
Old Jan 13, 2014 | 02:54 AM
  #40
isysman's Avatar
Wow this is complicated. So you couldn't fit the front bumper until this radiator and other parts were fitted, or you were just being particular about doing it correctly? Can you tell me what parts I'll need for under the front bumper? Radiator and this kit. Do you have part numbers? I really appreciate your help.
Old Jan 13, 2014 | 01:21 PM
  #41
SpecG's Avatar
I wanted all OEM and proper so I went thru it all. there are so many parts and the Germans dont list the items in common English lol. I ll list in English what I remember.
Front fenders
Front LR side indicator lights
Front bumper and lip
Front grills and clips (all 3 + 1 on top of bumper)
Front center radiator
Front center radiator frame
Front center radiator hoses
Front air inlet duct (all three)
Front air outlet duct (inside center)
Front wheel arch inner lining (L/R)
Front lip reinforcement (rectangle alu plate under the front lip)
Front LR side indicator harnesses
For the Rear bumper
Rear bumper
Rear exhaust shroud and clips
Rear heat shields (all three)
Rear intercooler brackets
Rear intercooler air outlet ducts (inside bumper)
Rear bumper support (behind exhaust)
Rear bumper protect (lower part of bumper with rivets, lower bumper mounts to bumper support)
Rear deck lid and wing
Rear deck lid rubber seal
Rear deck fan wiring harness
Old Jan 13, 2014 | 01:24 PM
  #42
SpecG's Avatar
went for some coffee with some buddies
Old Jan 13, 2014 | 10:20 PM
  #43
SpecG's Avatar
Appreciate the kind words its a friend's shop I'm using
Old Jan 14, 2014 | 03:27 AM
  #44
isysman's Avatar
Why didn't you take the parts from your old bumper?
Old Jan 14, 2014 | 05:20 AM
  #45
SpecG's Avatar
Managed to finish the tail pipes.. had to get some custom pipes done.
mind the two week dust
ID:	321174   Click image for larger version
ID:	321175   Click image for larger version
