997TT MK.1 PCM 3 conversion DONE :)
#316
I have a car from 02/2008 only with navigation, without bose, phone or other goodies.
Can you tell me which cables you had to adopt to get the pcm3 work?
I want a pcm3 as the pcm2.1 looks terrible and if possible with usb for mp3. Phone or Bose would be nice, but i think i wouldnt get it work.
I know Iandiman has an ASK amp for his conversion as his car is not Bose, so you could use an ASK amp out of a 997.2 car with PCM 3 and without BOSE - if you look back through the thread you will see Iandimans pics of the ASK amp he has bought.
I bought and modified this cable for the interface between my old PCM2.1 connectors - the quadlock end goes straight into PCM 3:
http://www.ebay.co.uk/itm/111182815136
#318
Yes, but better you obtain the schematics and you will see where the wires need to go. This is the official Porsche site for all data, I got my diagrams through here - they cost 8 euros each:
https://techinfo2.porsche.com/PAGInfosystem/VFModuleManager?Type=GVOLogin&lk=ELSE
If you PM me a will forward you any other documentation I have.
#319
This is what the above 'linked to' loom looks like after selecting the two correct connectors for the old PCM2.1 connectors and the new quadlock for the PCM3 and re-wiring it with the correct pin-out
#320
This is the re-pinning of the old Bose amp connector as the pinout is different for the new amp - also the wire colours are different - the 997.1 amp also uses a large connector and a small one with 3 wires in - the 997.2 amp just uses the one large connector - same as the old one - but it includes the 3 wires in it from the separate plug - all this becomes clear when you study the schematics.
#324
Thanks Iandiman - your encouragement helped hehe - I think most of the credit must go to Serg, he's the guy who originally did this and who lit the path! - Also guys don't be put off by his, at times, 'brief' responses! He's a good guy, probably gets a bit fed up repeating himself thats all - I think he would rather you had a go and then asked questions on particular issues when your stuck! Hats off Serg!
good job, good pictures!
do you have TP (traffic info) working in England?
#325
The only really outstanding unresolved issue, that I have not yet worked out a solution for is getting the AC controller to trigger the compressor - but I haven't given up!
#326
Thanks again Serg, yes the traffic info function works over here in the PCM3, and we also have a 7 digit postcode in UK and the latest software and maps which I now have on the unit enables this feature to work. Everything is working, really pleased - just got to install the new mics in the steering column and the iPod/usb interface into the arm rest - Ive got the parts on order for later this week.
#329
Hey Monster1,
A fellow UK (new) member here and i'm well impressed with your efforts! (and the guys beforehand who had the ***** to have a go)
Do you reckon this could be done with the ability to revert back to factory without splicing wires sockets etc?
I've got a 2007 997tt with Bose and I'd love a go at this if it was something that could be reversed if needed.
#330
PCM3 has no code for installation - if you install one, it will turn on and the radio and CD will work - but you need activation codes to release the nav, bluetooth, phone, iPod/usb functions etc
