Oil cooler for Tiptronic
Old May 31, 2016 | 01:13 PM
OK51MON's Avatar
OK51MON is infamous around these parts
Any joy with this?
Old Sep 15, 2016 | 02:36 AM
rik911's Avatar
rik911 is infamous around these parts
Also curious.
I have a 2002 NA 996 and looking for a nice fit cooler kit for the tiptronic transmission. Came across several posts which mention that ESMOTOR has a ready made cooler kit with a scoop. Curious to know if the kit ESMOTOR provided is still available and fits a normal 996.
I already have sent an e-mail to Emre and a PM via this forum. So far no reaction. No idea if he still reads this thread.
Old Sep 15, 2016 | 03:36 PM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Originally Posted by rik911
Also curious.
Hello,
Sorry to say that I have never tried it on 996, so i cant give you any feedback.
Regards,
Emre
Old Sep 17, 2016 | 02:26 PM
BADBRUNO's Avatar
BADBRUNO is infamous around these parts
997.1 with a Tip
My second gear is slipping, I have about 20k from tracking car.
Car makes about ~600 hp
Would like crisper shifts but still comfortable for My daily driver. Not drag racing. I think gear is gone from down shifting on Watkins Glen and other track. The car is located in Northern VA.
Any advice thanks
Bruno
Old Sep 18, 2016 | 07:52 PM
cdk4219's Avatar
cdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to all
Any advice thanks
Bruno
Find a shop that specializes in Mercedes kompressor, and turbo 65 transmission performance builds and send it to them. The 722.6 has an internal temp sending unit, so the trans temp is typically higher than the engine temp, and will probably climb well above 200 f with light spirited driving. If you get a large enough air to liquid cooler, you could disable the liquid to water factory cooler and rely directly in this. Placement of the cooler is the problem, if it is in front of the center radiator, the engine may get hotter. I totally separated my trans circuit, and using the stock heat exchanger on the trans and another radiator in front of the center radiator along with an intercooler pump I keep transmission temps below 55c (around 125f) over 30 mph with normal driving.
You may also add an air to liquid cooler in conjunction, but after the factory water to liquid cooler, so the trans is initially cooled by the engine coolant, and then travels to the air cooler for further cooling. Again placement of the cooler is the issue, and bigger is definately better. Regardless heat is the killer of the auto trans, keep it cool and keep it alive.
Old Sep 19, 2016 | 03:39 AM
rik911's Avatar
Originally Posted by Emre@Esmotor
Hello,
Regards,
Emre
Hi Emre,
Thanks for your feedback. Given the condition you still sell the cooler kit I am willing to give it a try to fit it on the 996 tiptronic.
You can send me a PM if you want.
Kind regards,
Old Oct 6, 2016 | 04:39 PM
rik911's Avatar
Hello,
Regards,
Emre
The 996 tiptronic transmission in my NA 996 is the 722.6 from Mercedes. It seems the 996tt and 997tt tiptronics do not differ too much with respect to physical lay out and cooling. I checked and all of them use stock the same liquid/oil cooler. Most probably the cooler kit will fit too under my car. As stated before i am willing to give it a try provided that you still have them for sale.
Fadi
Aug 17, 2018 05:16 PM
4080
Oct 5, 2015 01:45 PM
Twinturbofan
Sep 11, 2015 04:14 PM
m_motorsport
Sep 2, 2015 12:53 PM
