Clutch Slave Cylinder
Old Mar 8, 2013 | 11:38 PM
Zero Cool's Avatar
Zero Cool has a spectacular aura aboutZero Cool has a spectacular aura aboutZero Cool has a spectacular aura about
Well looks like it is starting to go bad as I found a small puddle of Pentosin fluid on the floor today. I knew it was just a matter of time as I had the accumulator replaced a few months ago. A few questions....
1) Has anyone had luck with getting Porsche to fix this "goodwill" with the car out of warranty and not being the original owner
2) I've read that after 2009 Porsche fixed the problem so if repaired with the upgraded part if should not happen as frequently. Any way to confirm this?? Did they change the design in the 997.2?? If not any 997.2 with this problem??
If there is no way to confirm this I was planning on changing to the GT2 setup to avoid failures in the future. As I have read there is no warning to when this will fail but I know it will eventually happen so I was going to get it fixed soon to avoid arriving on a flatbed.
Rich
Old Mar 9, 2013 | 08:07 AM
bbywu's Avatar
I had a friend have PCNA cover cost of labor, but he paid for the parts through the dealership as an out of warranty repair.
Old Mar 9, 2013 | 02:22 PM
otis's Avatar
otis is a splendid one to beholdotis is a splendid one to beholdotis is a splendid one to beholdotis is a splendid one to beholdotis is a splendid one to beholdotis is a splendid one to beholdotis is a splendid one to behold
I was just out of warranty by a month or two and way under in miles PNA paid for mine. Dealer went to bat for me.
Otis
Old Mar 10, 2013 | 04:39 AM
Zero Cool's Avatar
Thanks for the info......guess it will not hurt to ask
On another note, How much more time would it take to change the clutch as well. If it is not going to add much I'm thinking of adding the Sachs Stage 2.5 clutch kit.
Old Mar 11, 2013 | 12:10 PM
otis's Avatar
If I'd do it again I'm switching to the GT2 slave which doesn't leak and has a better feel.
Otis
Old Mar 11, 2013 | 03:13 PM
AlexM's Avatar
AlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant futureAlexM has a brilliant future
Make sure you try that unassisted clutch first.
With the ignition off, depress the clutch pedal about 30 times... it will get really stiff. See how you like it because that's what you will have to live with after the conversion.
Cheers, A
carwash
16
Oct 9, 2018 07:22 PM
jaehoppa
Oct 22, 2015 09:17 PM
sideboob
Sep 24, 2015 05:09 AM
Blue Chip
Sep 10, 2015 07:07 AM
ship it
Sep 7, 2015 10:49 AM
