seat belt for track day
Old Mar 31, 2013 | 08:37 PM
pretzel's Avatar
pretzel is infamous around these parts
First track day in TT coming up. Is there a way to get the oem belts to provide a constant tension (tight)? Last time out I was still in old 4S and occasionally felt that I was sliding around in the seat. I don't really want to put in a 5 pt. harness for a couple of days each year.
Old Mar 31, 2013 | 10:10 PM
amw's Avatar
amw
amw is a glorious beacon of lightamw is a glorious beacon of lightamw is a glorious beacon of lightamw is a glorious beacon of lightamw is a glorious beacon of light
I haven't used this, but have heard it works well.
http://www.cg-lock.com
Old Apr 1, 2013 | 04:09 PM
djben's Avatar
djben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond repute
If you have a power seat and OEM belts you have everything you need.
Here is what you do:
1) Move seat back.
2) Remove most of the slack from the belt.
3) Yank belt so it locks in place. Hold it there with one hand.
4) While ensuring constant tension on the belt so it stays locked, move seat forward to your normal driving position.
5) Done! Your belt should now be taught around your upper body and waist.
It will take some practice to make it perfect but it is the best you can do without a 5pt.
Have fun
Old Apr 1, 2013 | 05:56 PM
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
I used to have these when I tracked my CTS-V. Worked very well! Make sure you get one for the passenger seat too. Instructors don't like to be flying all over the place either.
Old Apr 1, 2013 | 08:07 PM
pretzel's Avatar
Will get two........
Curious though as a friend has an older (1995) Volvo sportwagon that if you pull the seat belt all the way out it ratchets back in, locking at each click. I think that it is designed for use with kids' booster seats but also works on the driver's seat. Seems that this type of mechanism should be available somewhere......
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
mjacobellis
Aug 20, 2015 09:13 AM
pwdrhound
Aug 20, 2015 05:54 AM
