lowering the beast
Old Apr 21, 2013 | 05:37 PM
baziturbo's Avatar
baziturbo is infamous around these partsbaziturbo is infamous around these parts
lowering the beast
Hi everyone.
I am debating lowering the car but would like to know the pros vs cons opinions of those who have done this. Also which set is recommended?
thanks in advance,
Bazi
Old Apr 21, 2013 | 07:52 PM
LeoLambo's Avatar
Lamborghini Fanatic
LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !
Pros better handle and more aggressive looks
Cons you will destroy the front spoiler
Old Apr 22, 2013 | 08:43 AM
40TO60N1's Avatar
40TO60N1 is infamous around these parts
+1 especially regarding the front spoiler. ;-)
(cost < $200 for stock part.)
Old Apr 22, 2013 | 09:44 AM
aa909's Avatar
aa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond repute
I recently lowered my car with GMG springs and could not be happier. The stance is much improved, and while subjective I think it makes the car look more aggressive IMO (assuming you like that kind of thing)
I also find the slop and loose feel of the front end, especially in non-sport mode, is greatly reduced.
The GMG springs bring the ride height down about 20mm (0.8") and I haven't noticed much more scraping of the front end. However I am more aware of entrance ways, ramps and bumps and try to take them at an aggressive angle. I assume if I approached some of these road conditions the same as with stock height I would likely scrape the front lip, but even so it is $200 and a simple DIY swap
good luck
Art
Old Apr 22, 2013 | 10:55 AM
DrVolkl's Avatar
DrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant futureDrVolkl has a brilliant future
good luck
Art
Do you have any suspension clicking or clunking? I lowered my last turbo with just springs and I'd get some clunking with full wheel lock. Been hesitant to do it again.... I wasn't using GMG however.
Old Apr 22, 2013 | 11:20 AM
LeoLambo's Avatar
Lamborghini Fanatic
I really wanna lower my car but with my luck I'm scare to do it.... $200 front lip is not a deal breaker
Old Apr 22, 2013 | 12:30 PM
Winnilaker's Avatar
Winnilaker has a spectacular aura aboutWinnilaker has a spectacular aura aboutWinnilaker has a spectacular aura about
Lowered mine, no issues. I have the clicking issue at full wheel lock, but had that before I lowered, so it wasn't related (just don't turn wheel all the way now ). Great on track and looks much better.
Old Apr 22, 2013 | 05:01 PM
baziturbo's Avatar
any rubbing issues with the tires? my front lip is the areokit version and not stock which is about 1k to replace.
Old Apr 22, 2013 | 05:10 PM
aa909's Avatar
I had the clicking/clunking under full wheel lock with the stock suspension/springs. Mine was more of the tires stuttering or rippling under full wheel lock but It's a fact of life with these cars, they all seem to do it to some degree.
Subjectively I've noticed the clunking to be better or less pronounced with the GMG springs and definitely not worse. Maybe when the tech installed the GMG springs and put the suspenion back together he tightened everything up better than how it left the factory
Old Apr 22, 2013 | 09:29 PM
alwaysturbos's Avatar
alwaysturbos is infamous around these parts
Same here, with the clunking noise at complete wheel turn, some times, not always.
I have H&R's that gave it a very aggressive drop, but no tire rubbing. Also have the oem aero kit, just go diagonal up slopes, you'll be fine
Old Apr 22, 2013 | 11:25 PM
Fugazi's Avatar
Fugazi is infamous around these partsFugazi is infamous around these parts
This was a easy choice for me Lowering is a must. The Pro is rides better and Con is you will scrape front end the first time is the worst.
Old Apr 22, 2013 | 11:51 PM
Fugazi's Avatar
Is there anything you can do for the Clicking & Clunking this is a "BIG" Con I thought I was the ONLY one having this issue.
Old Apr 23, 2013 | 08:44 PM
TT Surgeon's Avatar
Sometimes it's the rubber around the coils loose or moving, can let the springs spin slightly in their perch.
I'm thinking about a different route altogether, the b8s which are basically like a x73 designed to be used w lowering springs and stock links, pasm friendly, win-win.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Texas1
Sep 20, 2015 09:12 AM
