Sponsored by: Bears Transport
Power Kits? What works and is not overated?
  #106
Old 05-06-2013, 01:27 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Originally Posted by Tom@Champion
The only way for this measurement to be relevant would be if we compared several different exhausts on the same car with the exact same turbo setup. Every engine and every turbo setup is going to generate different amount of backpressure.
We have tested back-pressure on the Tubi Race (catless) exhaust with our 68mm VTG's and were very happy with the results. The car was running about 675 wheel horsepower at the time it was on the dyno, and we only saw a maximum of about 20kpa (about 2.5-2.6 psi) of backpressure. We also test with straight pipes (0 backpressure) and found that the car lost spool time and significant torque. That's why the Tubi Race system has a very carefully designed center muffler which is different from the normal catted street version. Straight flow but with a nice sound. People love to criticize our Tubi Race system...but not many people realize how much R&D WE here at Champion did to make sure that is simply the best performing exhaust for anyone looking to make power on the 997TT.
Here's a pic taken during our testing... (at this location, atmosphere was around 30)
Careful guys, with an atmosphere of 30kpa (= 4.4 psi) you'd all be boiling blood. I think that gauge is in inches of mercury (as are most US manifold pressure gauges), which would put your backpressure at an alarming 9.8 psi, assuming that picture is of a backpressure test. Please do clarify.
  #107
Old 05-06-2013, 01:57 PM
stef@europipe's Avatar
stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !stef@europipe Is a GOD !
Originally Posted by bbywu
Stef, is back pressure linear? For example, bigger turbos create more air flow, is back pressure directly proportional to the exhaust flow, or is it more exponential?
It is neither. The backpressure with our 70mm stage 2 sport exhaust on a stock 996 Turbo engine is 2.2 psi.
The same exhaust on a stock GT2 produces 2.2 psi as well and on a 996 Turbo K24 540 crank hp engine it is also 2.2 psi.
That's measured just before redline. On a build engine with 700 crank hp the maximum backpressure at 7800 rpm is 3.2 psi.
Nothing is so easy than a simple backpressure test.
  #108
Old 05-06-2013, 02:04 PM
That is easy: measure the backpressure on a stock engine
1) with stock exhaust
2) with the 200 cell Tubi
3) with the catless Tubi
That is an apples to apples comparisation.
If you feel that our 100 cell 3 inch exhaust with 1.75 psi backpressure on a stock engine is too restrictive for your 68mm VTG kit then I'll do my best to build a better exhaust. With all the R&D you've done on your Tubi exhausts you must have measured the backpressure of those exhausts on a stock engine. That's how we do it and that's how every other exhaust manufacturer does it. Please share your data.
With straight pipes torque and spool time is lost indeed. With short 20 inch straight pipes that is. Most of the loss is due to the short lenght of the straight pipes and not because of the low backpressure. With long straight pipes, the 60 inch version that runs from one side to the other, you won't have the same torque loss problem.
  #109
Old 05-06-2013, 02:33 PM
Josh/AWE's Avatar
Originally Posted by elite1
I will be investing in a power kit this summer for my 997.1 TT. I currently have the Europipe stage 2 exhaust. What power kit truly gives a reliable and powerful result? Cost is not much of a concern but, I would like to install it myself. I am currently awaiting a Max Jax 2 kit to be delivered. I get too nervous under a car!<O</O
elite1,
Apologies for taking so long to comment in this thread.
The fact that you want to install a package yourself is very intriguing and I am glad to hear it. There is nothing better than a user purchasing and installing themselves then posting a positive review.
One of the first users of our 750 kit was 6speed user, eclou. He took the time to install the kit himself, in his garage, with just his basic metric hand tools. He also documented the whole process.
This post has helped me sell many turbo kit. I suggest checking it out when you have time. It is very detailed. Click HERE.
If you have an specific questions about our kit, please shoot me an email. I am glad to help.
Mike@AWE-Tuning.com
Finally, for those that want to read more about our what we offer, see below.
CLICK!
Thanks for reading and we hope to hear from you soon.
  #110
Old 05-06-2013, 02:43 PM
w00zy's Avatar
w00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to behold
I hope can reach 800PS with my Europipe and the A3071's
  #111
Old 05-06-2013, 03:06 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Getting some clarification on this now....I'll as Louis to chime in or give me the info.
Stef...I think you misunderstood what I was saying. I have not tested the kit with your exhaust, so I'm not suggesting that it won't work. You can always run cats with our kit if you prefer it...but it will sacrifice some power. How much power....not sure unless we test it. We've only tested cat vs non-cat on our 68 kit with the Tubi exhausts and the difference is about 40whp. Your exhausts are great products, we've installed quite a few of them here. Our preference is just for no cats at all on our VTG kits...
  #112
Old 05-06-2013, 03:18 PM
yumaverick's Avatar
yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !
Tom,
What's the performance difference between a Catless x-pipe like proto or 911 tuning makes compared to a tubi or cargraphic Catless? Do the x-pipes produce more power or same power just save on weight?
  #113
Old 05-07-2013, 04:31 AM
cannga's Avatar
The only way for this (back pressure) measurement to be relevant would be if we compared several different exhausts on the same car with the exact same turbo setup. Every engine and every turbo setup is going to generate different amount of back pressure.
Tom, very interesting observation as usual.
Is it the above because max back pressure is directly related to boost pressure (and different cars have different boost pressures)?
  #114
Old 05-07-2013, 04:55 AM
cannga's Avatar
Nothing is so easy than a simple back pressure test.
Stef, could it be that Tom and you are talking about 2 different measurements?
Tom's seems to be talking about a "maximum-hold" value in a dyno run. This max value could be at any RPM, wherever the boost is highest in that particular car's boost vs. rpm curve. Whereas yours seems to be a more steady-state number at red line?
If above is true, I would expect Tom's back pressure number to be higher than yours?
  #115
Old 05-07-2013, 02:01 PM
No
Let's move on: Power kits? What works and is not overrated?
  #116
Old 05-08-2013, 09:40 AM
cannga's Avatar
Not for Stef obviously, but there is a reason for my curiosity of back pressure. I don't see it mentioned on any exhaust web site such as Tubi or Akrapovic or Cargraphic http://www.akrapovic.com/en/Automoti...s/default.aspx , NEVER even as part of advertisements.
I suspect this is because this number, as Tom mentioned, is car and system dependent; it is hard for me to think that it's not dependent upon for example how big the turbo is, and how much boost is being generated, the volume of air flow, etc. You could compare it within same car, but not across different cars, where it could/would become invalid. How to measure is another sticky point: peak hold vs. steady state at certain rpm. In other words, there is no industry standard - am I wrong? In this day and age of internet and google, if it's not posted anywhere, isn't that a sign that there is none?
  #117
Old 05-09-2013, 12:13 PM
Well the backpressure at 6500 rpm with 0.8 Bar turboboost is much higher than the backpressure at 4000 rpm with 1.2 Bar turboboost.
I can do some runs on my otherwise stock 997.1 Turbo and share the data if you're interested.
  #118
Old 05-09-2013, 12:18 PM
  • 65mm -- Between 580 and 600 whp on pump gas, 610 - 615 on race gas
  • 68mm (with stock engine) -- 650 - 660 whp on pump gas, 675 - 685 on race gas
  • 68mm (with built engine) -- 765 - 775 whp on pump gas, 785 - 800+ on race gas.
Hope this helps answer some of your questions. Feel free to let me know if you have any others.
Tom, what have the GT2RS turbochargers in common with your 65mm turbochargers?
  #119
Old 05-09-2013, 12:22 PM
cannga's Avatar
Yes I would love to see the data, especially if it's done at same RPM with different boost pressures, as in 2 different programs. Secondly, not related to our discussion, but for "academic" purpose it would be wonderful to have back pressure grafted against boost pressure and other log data on a curve: rpm on x-axis, back pressure/boost/timing/AFR/etc. on y axis. I am certain the big boys do this when they dyno their exhaust but I am not sure if it's possible with the current method?
My question has not been about whether your measurement is accurate, but whether it is a valid number that could be interpreted across different cars and manufacturers. In other words, for example, could we use your measurement against the measurement of say Akrapovic?
My reading so far, and what Tom has written, indicate that it cannot be and that is why no one publishes this number. The point of measurement (how far downstream you are from the cat), the boost, the engine, are all variations that make this measurement valid only in one particular car, not across cars or across manufacturers. Just theorizing of course, I don't mind being corrected by the experts on this field.
  #120
Old 05-11-2013, 10:57 AM
The point of measurement is between the turbocharger and the cat. All the 993 Turbo, 996 Turbo and the 997 Turbo stock exhausts have an extra bung to measure the backpressure. So the position of measurement is the same for everyone, the stock engine is the same too and I run my car with the sport chrono button activated. I've measured the backpressure during different weather conditions, while freezing and at 25°C and the results were identical. What other variations have I overlooked?
Quick Reply: Power Kits? What works and is not overated?
