How good is your factory Airbox... We test it!
Rating: Thread Rating: 3 votes, 5.00 average.
Old May 23, 2013 | 08:01 AM
  #46
AMS's Avatar
AMS
AMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond reputeAMS has a reputation beyond repute
Originally Posted by AMS
We are unsure of what core Champion uses to construct their IC's, but from our findings we offer by far the largest IC's on the market. They will surely support a 1200+ HP setup.
I grabbed some info from Tip car we are finishing up. This 997 also has an aftermarket open filter intake.
84 degree day
idle IAT was 107 degree
2nd thru 3rd gear pull we saw 116 degree
This was at approx 1.5 bar / 800 awhp.
please let me know if I can be of any further assistance
Larry
This car also had one of the 'Hot air intakes' on it, hence the 107 degree intake air temps when cruising. 30 deg F over ambient just cruising. If we sat at idle with the car not moving it would probably go even higher.
-Martin
Old May 23, 2013 | 11:01 AM
  #47
bbywu's Avatar
84 degree day
Larry
Hello Larry,
Would you be willing to share a datalog of peak temperatures on a high speed run? It would be very useful for those of us who are looking to invest in improved ICs.
Looking at your post, it appears your idle temp was very high, even for the ambient temperatures with the aftermarket intakes.
Old May 23, 2013 | 11:18 AM
  #48
kenromero's Avatar
kenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond repute
I didn't see a comment on the 'air inlet tubes'. Do you believe that one would not experience a benefit by changing the Porsche stock inlet tubes? I hear from many sources that the stock tubes are restricted in size by the body and frame and therefore cannot provide as much air to the turbos as the fenderwell intakes do. I would think that by dramatically reducing the air flow distance to the turbos and providing a higher volume of air to the turbos that we would receive a quicker spoolup and reduced lag. Has anyone dyno'd a before and after?
Old May 23, 2013 | 11:40 AM
  #49
AMS's Avatar
AMS
Originally Posted by bbywu
Hello Larry,
I will see if I can get you a log as you've requested. The idle temps were high due to the open aftermarket intakes.
Larry
Weebs
Nov 29, 2018 08:20 AM
Apex Chase
Mar 28, 2016 02:00 PM
MDYUKI1016
Aug 24, 2015 04:40 PM
Weebs
Aug 21, 2015 06:35 PM
ritchrwi
Aug 20, 2015 05:19 PM
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
