dumb question but does a 2008 tip turbo have a launch function?
Old May 27, 2013 | 05:29 PM
baziturbo's Avatar
baziturbo is infamous around these partsbaziturbo is infamous around these parts
sorry for Noob question but I am trying to figure out how to launch without just flooring the throttle
thanks
Old May 27, 2013 | 05:43 PM
Fugazi's Avatar
Fugazi is infamous around these partsFugazi is infamous around these parts
Good question I have a Tip also and would like to know. I'm pretty sure Power-Braking is the only way. If that's the case I'm out $15 G's for a new Tranny NO thanks!!!
Old May 27, 2013 | 05:52 PM
Slate997TT's Avatar
Slate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant future
What do you think? I'll give you a clue it does not have an iPod connection or Bluetooth!!!
Old May 27, 2013 | 06:22 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
thanks
No launch control on your cars. You can brake boost, but not a great idea, as you will eventually toast your Tip.
DC
Old May 30, 2013 | 03:41 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Hello,
Turn on Sport mode, PSM OFF.
FULLY press brake pedal and then kick throttle pedal quickly.
You will see "Overboost arrow" in the instrument cluster. It means the car is in launch mode.
Its not an official "Launch mode" but its the correct way of launching.
wait till boost pressure goes up to 0.3 - 0.4 bar then take your foot off the brake.
It will launch perfectly if you tires are in good condition
Cheers,
Emre
Old May 30, 2013 | 04:47 AM
slawek's Avatar
slawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond repute
Emre you are absolutely correct ,one thing to add is to have long straight road in front of you and and hold to your life.
Old May 30, 2013 | 07:45 AM
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
With stock power I launched my car countless times without seeing any leaks or slippage of the trans. Only when I added my modded VTG turbos is when I started seeing the abuse the launch was doing to my trans. Sometimes if theres no need to launch hard but still get off the line I keep my foot on gas and brake still just to keep revs up not necessarily push the boost through from a stop. Its a way to eliminate SOME Lag from a dig.
The real fun comes when you mod the trans, Built Transmissions hold the power like no other.. Tony @ EPL was able to add brake boosting from rolling speeds to my tune., where before traction control would eliminate that from happening.. I have been beating on it and not worrying about it for the last 20k miles also .)
Old May 30, 2013 | 12:11 PM
MK23's Avatar
MK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud of
I agree with all on the way to launch it. But be warned, at some point, you will have the dreaded "seal leak" from the tip trans. Mine was replaced under warranty but I was told it would have been $15K otherwise. Which really sucks because all of the press releases and reviews of the 07-08 tips, both from Porsche and from car mags, discuss brake boosting to get those 3.3 0-60 times. The problem is that you're only as strong as your weakest link and in these cars, that appears to be a small rubber seal that requires the whole transmission to be replaced.
Old May 30, 2013 | 05:06 PM
dgreen78's Avatar
dgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond reputedgreen78 has a reputation beyond repute
Does Tony have a TCU upgrade software option for the 997tt?
Originally Posted by Emre@Esmotor
Hello,
Cheers,
Emre
I sent you a PM last week about trans kit but have not recieved a reply. Can you check your PMs?
The_Ruski_Driver
Oct 25, 2015 08:40 PM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
Aug 21, 2015 06:34 AM
ppwchiang
Aug 20, 2015 10:28 AM
