Help! Purchasing 997 Turbo and not sure what to make of over rev report
Old Oct 14, 2013 | 09:07 AM
TurboBoostin's Avatar
TurboBoostin is a splendid one to beholdTurboBoostin is a splendid one to beholdTurboBoostin is a splendid one to beholdTurboBoostin is a splendid one to beholdTurboBoostin is a splendid one to beholdTurboBoostin is a splendid one to beholdTurboBoostin is a splendid one to behold
Hi everyone, I'm getting ready to purchase my first Porsche this week. I received the over rev report and I'm not sure what to make of it. I've seen mix reviews and feedback regarding how to read it. It's a 997.1 Turbo w/15k on the clock.
The over rev report reads:
Range 1 - 1752
Range 2 - 391
Range 3 - 64
Range 4 - 1
Range 5 - 0
Range 6 - 0
I've referenced the Porsche charts regarding RPM ranges but my questions to everyone here is:
1. Does this seem like it's been excessively revved compared to your car or others with similar mileage?
2. Would you purchase this car if it met your requirements?
3. Could there be engine damage?
Thanks for the feedback
Old Oct 14, 2013 | 09:42 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
In my opinion there's nothing shocking there. I personally wouldn't worry too much.
There are no range 5 and 6 which is good. That's where you would see a serious mechanical over-rev, like a missed downshift or something. Range 1-3 aren't that serious in my opinion, especially only 64...that means it really only happened once, maybe twice.
Old Oct 14, 2013 | 11:13 AM
lat42loon71's Avatar
lat42loon71 is infamous around these parts
DME decode
Turbo
Deciphering the DME report goes like this:
Each range, 1-6 corresponds to an RPM range. Don't know exactly what the 997 turbo numbers are, but generally range 1-3 over revs are "acceptable", 4 and above are a relative concern.
Here is what the numbers mean.
The engine DME records cylinder ignitions (sparks) when thery occur within the ranges 1-6. Below ranges 1-6 are lower rpm.
With an engine operating at ~3000 rpm there are ~50 revs/sec, with 6 cylinders makes it ~300 sparks/sec.
With an engine operating at ~6000 rpm there are ~100 revs/sec, with 6 cylinders makes it ~600 sparks/sec.
Each count (1752) in range 1 indicated the engine spark occurred above the specified rpm - maybe in the 7000-7200 rpm range for range 1. So let's say a missed down shift occurred and it lasted ~1 sec, it would record ~699 range counts (7000/60=116, x6=699). If it was a fraction of a sec., let's say 1/10th, it would be ~69 counts.
Same logic applies for the higher ranges.
I'd say you OK with the numbers indicated.
Bob D
Old Oct 14, 2013 | 01:15 PM
thanks for the information. That makes me feel comfortable making the purchase.
Old Oct 14, 2013 | 02:58 PM
djben's Avatar
djben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond reputedjben has a reputation beyond repute
Only 1700 range 1s?
Car was really never driven hard. This is pretty much a perfect DME.
Old Oct 14, 2013 | 06:08 PM
Turbo
Did you receive a printed DME report? or another form?
Did the report with the range counts numbers posted include the exact 997 Turbo/GT2 VIN that linked the report to the car?
I'd like to see the actual report showing the VIN and the range counts, for my use for other reasons.
If you have it please send, or attach to a post.
You can't PM the report until you have 5 posts, but I'll get you my email.
Thanks -
Bob D
Old Oct 15, 2013 | 09:15 AM
Originally Posted by lat42loon71
Turbo
Thanks -
Bob D
Out of town now. I'll send info when I get back next week. thx
Old Oct 15, 2013 | 05:16 PM
maverickdxb's Avatar
maverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond repute
+1
I have 5 ignitions on range 4, happened almost 7 months back, car is fine and I tuned it recently too
range4 happened during a spirited drive when the intended 4th gear slipped back into neutral and i stepped on throttle. Many people i talked to claim this is not possible as the limiter would stop that from happening. I hit the rev limiter recently after my tune and it recorded ignitions in ranges 1-3, but never 4. The tune did not increase my redline. I read somewhere else on the forum that the DME sometimes records this information incorrectly.
Anyway, the car is running perfectly and I had no issues at all. Hope this assures you and best of luck with the purchase
Old Oct 16, 2013 | 10:05 AM
triblk6spd's Avatar
triblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond repute
Its completely fine. Even if those numbers were double...it would still be fine.
Old Oct 16, 2013 | 05:01 PM
amw's Avatar
amw
amw is a glorious beacon of lightamw is a glorious beacon of lightamw is a glorious beacon of lightamw is a glorious beacon of lightamw is a glorious beacon of light
djben is right. That reports shows minimal use. Best of luck with the purchase!
Old Oct 19, 2013 | 02:18 PM
NCP19's Avatar
NCP19 is infamous around these parts
This is an interesting article. I never knew these reports existed in Porsche's computers. This really makes the buying experience for the buyer a littler easier (piece of mind). However, does it allow us to really "enjoy" our cars like they were built to be?
Old Oct 19, 2013 | 08:50 PM
Purchased the car on Thursday. Mint condition. Now I have to wait for it to arrive from the Midwest. Thanks for the quick feedback, guys. Much appreciated.
Old Nov 14, 2013 | 07:16 AM
nutbush997's Avatar
nutbush997 is infamous around these parts
997 turbo over rev
I have had my 2007 997 turbo tested for over rev by a reputable independent Porsche dealer who wanted to buy it. He could not buy it because he was not happy with the over revs, I cannot remember the figures exactly but I do believe he was genuinely dissapointed not to be able to buy it. Apparently it happened on a downshift ( sorry to be so vague) He said he would be interested in the car again after 200 hundred hours and a compression test. I have since decided to keep it and would like to know if I have to now take special care with the car or do I continue as normal ( i am a mature driver so don't thrash the car everywhere) but I have been invited on a track day tomorrow and am wondering if it is advisable?
I would appreciate any quick replies before tomorrow please.
Old Nov 14, 2013 | 07:59 AM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
He is waiting for the 200 hours because if there was an issue from the over rev, it would show itself by then. If it is ok in 200hours then the motor is fine.
Continue to drive as normal!
Old Nov 14, 2013 | 08:25 AM
jhbrennan's Avatar
Get ahold of the December issue of Excellence magazine - very good article on over revs. Should help you out. Same article is in one of the UK Porsche magazines too - can't remember which one though.
