Plastic Cooling Pipes
Old Feb 5, 2014 | 09:52 AM
Amit Likhyani's Avatar
Amit Likhyani is infamous around these parts
Looks like mine have a small leak around the oil cooler on the front of the motor. Just want to make sure: the motor has to come out to replace them, correct? And at that point, might as well get the Sharkwerks set or is there something better or reason not to get them?
Thanks,
Mit
Old Feb 5, 2014 | 09:54 AM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
Yes the motor has to come out.
I haven't heard any differences in the weld in kits.
Old Feb 5, 2014 | 10:57 AM
sharkster's Avatar
Yep the engine has to come out... here's the pertinent info:
http://www.sharkwerks.com/products.php?pid=394
Old Feb 5, 2014 | 01:40 PM
93ls1rx7's Avatar
Wow, I didn't realize that they cost $500 for 3 small pipes...
Old Feb 5, 2014 | 01:42 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
And they cost more $600 shipped to the U.K.
Old Feb 5, 2014 | 02:42 PM
kenromero's Avatar
kenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond reputekenromero has a reputation beyond repute
Ditto, the engine must be dropped. I did mine last month. BTW this is an XLNT opportunity to replace your injectors!!!!
Old Feb 6, 2014 | 11:20 AM
Dan@SharkWerks's Avatar
Dan@SharkWerks Is a GOD !Dan@SharkWerks Is a GOD !Dan@SharkWerks Is a GOD !Dan@SharkWerks Is a GOD !Dan@SharkWerks Is a GOD !Dan@SharkWerks Is a GOD !Dan@SharkWerks Is a GOD !Dan@SharkWerks Is a GOD !Dan@SharkWerks Is a GOD !Dan@SharkWerks Is a GOD !Dan@SharkWerks Is a GOD !
Hey guys,
Thanks for the feedback on these parts, it's just something we discovered as a problem from rebuilding/repairing engines and coolant leaks on these cars. (http://sharkwerks.com/porsche/techni...urbo-cars.html)
Unfortunately we do not have the equipment to build these weird parts in house, requiring tube bending equipment and CNC mills for the end pieces, TIG welding assembly and o-rings. For us it's a custom, low volume part, and for our limited production the only way we can justify making and selling them involving the warranty/liability that goes with it, we have to charge what we do. We have these made here in California so we can oversee production and it's a lot more expensive than outsourcing overseas.
If the price seems steep you can always replace the pieces with another set of the original plastic pipes from Porsche (about $100?) but as we've discovered, they do tend to fail eventually and the labor/cost involved in replacing them can exceed $3000 and you might experience a couple weeks of downtime for your car.
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Rguy
Apr 12, 2020 11:11 PM
sleepy
Sep 4, 2015 11:59 AM
yumaverick
Sep 2, 2015 03:48 PM
