Rear tires
Old Apr 9, 2014 | 09:13 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
That's what I'll be doing as well. Thanks for the information.
Old Apr 9, 2014 | 09:32 AM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
Originally Posted by ryem3
I've been running PS2's in the front and PSS in the rear with no issues whatsoever. Michelin lists the PSS as a replacement for the PS2, so this is even a recommended replacement from Michelin. However, the wear indexes are considerably different, so you would think there would be a considerable traction difference. Reality is, there doesn't seem to be and the PSS's get even better traction than the PS2's.
I agree, also the rears will wear faster and catch up to the fronts in no time. The problem would be worse if the fronts were newer than the rear. The problem isnt the tread pattern its grip. Newer tires will have more grip than older. So you are adding more grip to the rear. For a little while as they wear faster.
The PSS vs PS2 is not a huge difference. I know all the pro drivers here can tell but I am guessing one of us can run our tuned suspension PSS shod cars against a porsche driver like Mark Weber in a bone stock with PS2 and he will destroy us all day. Point lots of us have a great butt dyno and butt feel but its not as signifigant in reality
Old Apr 9, 2014 | 09:35 AM
WaltB's Avatar
WaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond repute
I do not think it would really be that big of a deal actually. Certainly the traction coefficient would be different however you change that on any given tire by changing the camber adjustment and or adding sway bars and selecting different tension settings too.
Walt
oufan2929
Nov 8, 2015 08:26 PM
L.A.P.
Oct 19, 2015 10:01 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
L.A.P.
Aug 23, 2015 11:48 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
